Tapered Carbon disc fork 1 1/8 - 1 1/4 -what are my options?
Hi,
I contemplating on purchasing a CX frame that comes without a fork.
It requires a tapered 1 1/8 - 1 1/4 disc brake fork, but when I look around online and on eBay i mostly find 1 1/8 - 1.5" (1 1/2).
Also I'd prefer a 45mm rake.
So what options are out there?
Current: Colnago CX Zero Di2 Disc, Cannondale F29 carbon3
Previous: Scott Plasma 3 premium, Parlee Z3SL, Parlee Z4, Argon18 E112, TREK TTX7.0, S-Works Transition, Pinarello F4:13
Whiskey Parts Co. is the only obvious choice I can think off without using Google
Its a Focus frame. Only Focus will work?
mattjevans wrote:Enve ?
Err.. We can start just dropping manufacturer names followed by "?", that would be really helpful
I allready looked at ENVE and and AFAIK Enve only do the CX fork in 1.5".
- rasmussloth
yes, thanks. The HD9900 1-1/4 to 1-1/8 would be an option and then go for a non tapered 1 1/8 fork.
I need to read reviews of 1 1/8 forks used in CX then. I assume the reason for using tapered 1 1/4 and more common 1.5" is to add stifness to the front end.
I'm just bumping this in hope that anyone have spotted a 1 1/8 - 1 1/4 tapered CX disc fork.
One the other reasons for the push to bigger steerers for cx is due to the use of canti brakes: If you have flex in your fork steerer using a headset mounted cable stop, you get some real nasty shuddering in your front braking due to the in phase oscillations that can result. Its common to go to a fork mounted hangar or mini-v's to work around this.
There may be less of a need for the tapered steerer with a disc fork, which may be why you are having issues sourcing one.
- Shop Owner
THE TRP Fork will be available in 4-5 weeks.
http://forum.cx-sport.de/showthread.php?t=6089
CX RACE 12.12.15 http://www.cx-sport.de/content/cyclocro ... cup-cochem
aaric wrote:One the other reasons for the push to bigger steerers for cx is due to the use of canti brakes: If you have flex in your fork steerer using a headset mounted cable stop, you get some real nasty shuddering in your front braking due to the in phase oscillations that can result. Its common to go to a fork mounted hangar or mini-v's to work around this.
I don't think there are any canti bikes with 1 1/8 - 1 1/4 forks out there in the marketplace.
http://demarere.blogspot.com/" onclick="window.open(this.href);return false;
Luckily my frame is for discs
there was a Colnago one on UK ebay the other day, so they do exist...
..here you go
http://www.ebay.co.uk/itm/COLNAGO-WORLD ... 19fb003301
..here you go
