Vitus VR Energie v Focus Mares CX 2.0
liam7020
by liam7020
Thinking of shortly buying a new mid-range crosser and currently deliberating between these two:
http://www.chainreactioncycles.com/vitus-bikes-energie-vr-cyclo-x-bike-2015/rp-prod120681
or
http://www.focus-bikes.com/gb/en/bikes/2015/triathlontt/e-planet/mares-cx-20-disc.html
Anyone ridden either or both? On paper the Vitus seems like the better deal and, having actually seen one in the flesh at the CRC showroom, it does look very trick indeed, but since I've never had a disc brake bike before any comments or advice would be appreciated. Cheers.
Tarmac SL6 & Campag Record EPS https://weightweenies.starbike.com/foru ... 0&t=153968
Peter_E
by Peter_E
If the Geometry suits you I would go for the Focus. Nothing wrong with the Vitus but it is likely to me that Focus knows more what to do for a good cross Frame/fork.
liam7020
by liam7020
I'd be looking at the 54.5cm in the Vitus and the 56cm in the Focus. In terms of the geometry I would probably lean towards the Vitus which has a longer headtube and a slightly shorter top tube.
rasmussloth
by rasmussloth
It's a brilliant new frame.
