It is currently Tue Jan 23, 2018 10:58 am
Post new topic  Reply to topic  [ 2 posts ]
PostPosted: Sat Aug 16, 2014 7:35 am
1) Did you mount the chainring where the outer or inner chainring used to go?
2) What chainring screws/bolts did you go with and what is their orientation?
3) What spacers did you use for the hidden bolt if you mounted the chainring on the inside?
Basically, describe your setup in detail if you could.
I have a set of 10-speed carbon Chorus cranks. I bought the 42T, 135BCD Thorne Koksijde chainring for single ring application from cyclocrossworld.com. I also bought shorter single speed chainring bolts. My initial thought was to mount to the inner position. This didn't work out well at all. No extra spacer to take up the gap the the outer chainring usually filled. Singlespeed chainring bolts I bought don't at all play nicely with the Campagnolo spider arm thru hole diameters. The Campagnolo bolts don't work either, no matter if I put the bolt on the inside or the outside. So I tried the chainring in the outer position. Again, the singlespeed bolts I bought don't work at all. Surprisingly, the stock Campagnolo bolts do work, except for the hidden bolt. For that, one of the shorter singlespeed seems to work. My only worry now is the chain clearance to the back of the crank arm.
Any help would be appreciated. I can't find any pictures out there on the Interwebz.
Time VXRS Ulteam (7.16 kg)
viewtopic.php?f=10&t=120268
PostPosted: Fri Aug 22, 2014 7:20 pm
I have my single chainring on the inside. See my topic on Campy narrow-wide single ring set up for details. This should answer your questions aswell. http://weightweenies.starbike.com/forum/viewtopic.php?f=4&t=127393
For sale: Colnago Master PRZA frameset 58cm
My other bikes:
CX: Stevens Team Carbon Campagnolo Record 10spd; 2x
MTB: Deng Fu 29" XTR, rigid
SS road: Gazelle Special Reynolds 853 Trapezi
There are no new unread posts for this topic. Short cage or long cage RD for 32t cassette on single chainring?
Ed209
Thu Aug 03, 2017 9:54 pm
Ed209 View the latest post
There are no new unread posts for this topic. When will Campa release EPS 2.0?
vlastrada
Mon Mar 06, 2017 3:50 am
Seedster View the latest post
There are no new unread posts for this topic. Campa Ultratorque issue
marshalus
7
1061
Wed Mar 29, 2017 12:44 pm
marshalus View the latest post
There are no new unread posts for this topic. Need help on power2max Type S Campa 2015
poppiholla
7
662
Sat May 27, 2017 10:35 pm
poppiholla View the latest post
There are no new unread posts for this topic. Maintenance of Campa SR bottom bracket/ bearings on Colnago C60
TonyM
13
798
Thu Oct 12, 2017 5:17 pm
Calnago View the latest post
Users browsing this forum: No registered users and 2 guests
