It is currently Mon Jan 22, 2018 5:39 pm
 Post subject: CX tires for MTB mud.
PostPosted: Sun Jul 27, 2014 12:53 am
I am currently planning a 29er MTB build and I am thinking about getting some CX tires for when it gets really muddy as I have never had great experience with mud tires as my rides have some road riding too and mud MTB tires suck all speed on the road. And I could save around 300-400g per tire!
Anyway It'll be a 29er carbon and rigid, but I know nothing about CX tires, so any advice would be great :) tubeless compatibility would be best too.
PostPosted: Sun Jul 27, 2014 4:05 am
If you want tubeless, I would recommend the Clement Crusade PDX
PostPosted: Sun Jul 27, 2014 8:21 am
Thanks, do you know what rim width (internal or external) that would work with these? As most XC rims are a 21mm internal, but I was considering some with a 28mm external and 23mm internal. Mainly for a stronger wheel to cope with being ran as a rigid.
PostPosted: Tue Jul 29, 2014 5:38 pm
Not sure of a max size. The tire is a 700x33 claimed, have seen a lot of folks using them on Stans Iron Cross without issue (wider rim). You might send them an email or call to see if they have a suggested max rim width.
PostPosted: Tue Jul 29, 2014 8:42 pm
I used Stan's Crest rims with Clement PDX tires for most of cross season last year. My experience trying tubeless was miserable, and I had multiple DNF's due to burping or complete failure. I don't recommend the combo (for tubeless). However, I am very fond of the tires and rims as seperate components, and have very good experience using latex tubes. YMMV
By the way, my PDX's measure at about 35mm on the Stan's rims.
Moloko Plus 6.24 kg
"We haven't located us yet"
PostPosted: Tue Jul 29, 2014 11:43 pm
I have a couple of friends running the wire bead Challenge Grifos as tubeless (the black in wall ones). You could also try the Maxxis Mud Wrestlers or Michelin Mud 2 - not sure how they go as tubeless though but would be great with Challenge latex innertubes. Maybe even the Vittoria XL mud tire, also the Shawlbe Racing Ralph and Rocket Ron would be good but they are kind of a race tire more than anything
2012 BMC SLR 6.02kg http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=110390
PostPosted: Wed Jul 30, 2014 6:24 am
From my experience Schwalbe Racing Ralphs are not good for muddy conditions as they do not clear mud very well. They have also relatively small volume, so you have to run them with a little more pressure. I have them currently set up as tubeless on Iron Cross Rims. I am currently also searching for options with a Grifo like tread, more volume like the Schwalbes and Tubeless capable...
PostPosted: Thu Jul 31, 2014 1:55 am
The Vittoria XG is like a Grifo tread but not sure how it would go as tubeless
There are no new unread posts for this topic. Zondas can I use 23 mm tires??
in Everything wheels
Luv2ride60
Tue Feb 07, 2017 11:01 am
GambadiLegno View the latest post
There are no new unread posts for this topic. Suggestions on tires
addictR1
9
1084
Sat Jun 10, 2017 11:42 am
wheelsONfire View the latest post
There are no new unread posts for this topic. Skinny tires in the TdF
Asteroid
14
1931
Thu Jul 13, 2017 11:46 am
Stolichnaya View the latest post
There are no new unread posts for this topic. Attachment(s) Tubular Tires!
addicted
Thu Nov 30, 2017 2:16 pm
addicted View the latest post
There are no new unread posts for this topic. Winter cross tires
CallumRD1
Wed Oct 18, 2017 8:07 pm
youngs_modulus View the latest post
Users browsing this forum: No registered users and 1 guest
