It is currently Wed Jan 17, 2018 9:26 pm
Post new topic  Reply to topic  [ 7 posts ]
 Post subject: Ultegra 6700 Pulleys
PostPosted: Thu Jul 10, 2014 9:58 pm
I'm piecing together a CX bike (very early stages - no frame yet), but I do have some of the components, which are hand-me-downs from my wife's road bike. I've discovered that the top pulley on the rear derailleur (Ultegra 6700) has a lot of drag, much more than the lower pulley, so I'm going to replace it. What pulley do you recommend? I can always go with a replacement Shimano pulley, but since I've already got this one apart, I figure I might as well upgrade the parts to something stronger/lighter. Any recommendations?
Thanks,
 Post subject: Re: Ultegra 6700 Pulleys
PostPosted: Fri Jul 11, 2014 6:04 am
Trax (spelling?) Makes some rad ceramic bearing ones.
PostPosted: Fri Jul 11, 2014 9:11 am
Administrator
My road bike is now using VCRC ceramics which I spin very nicely. Plus you can relube the bearings. I'm strongly considering them for my cross bike.
RESIDENT GRUMPY OLD MAN.
PostPosted: Fri Jul 11, 2014 9:14 am
This is normal. One pulley uses bushings the other uses bearings
PostPosted: Sat Jul 12, 2014 12:39 am
The top pulley has more friction than I've ever seen before on a derailleur. I always noticed that her bike had some resistance, but was never able to pin it down until I pulled her drivetrain when I swapped in the 6800. Since then, no issues whatsoever with friction. I definitely think this pulley is shot.
Thanks for the suggestions, guys. I'll look into them.
PostPosted: Wed Jul 23, 2014 11:34 pm
I have had both Tacx and KCNC. The Tacx keep the shifting performance high but the looks are boring. I KCNC has a bit more lateral play rolls equally well and comes in color. As said before the stock upper pulley was underwhelming on a good day. If looks are not a big consideration go with Tacx.
PostPosted: Thu Jul 24, 2014 8:03 pm
Thanks for the recommendation. I ended up getting an Ultegra upper from my LBS, who had it laying around (free). If it dies on me at some point in the future, then I'll upgrade the set.
There are no new unread posts for this topic. Attachment(s) Ultegra 8000 pulleys - both bearings?
evren
Tue Sep 26, 2017 1:49 pm
ooo View the latest post
There are no new unread posts for this topic. Caliper: Tiagra 4700 vs Ultegra 6700
WiryMike
Mon Feb 27, 2017 4:31 pm
hambini View the latest post
There are no new unread posts for this topic. Larger pulleys longer chain?
desperado95219
Sun May 14, 2017 8:45 am
mattr View the latest post
There are no new unread posts for this topic. 15 tooth ceramic pulleys plus long cage for dura ace 9000 and 9070 rear derailleurs
mike
Sat Oct 14, 2017 2:29 am
mike View the latest post
There are no new unread posts for this topic. New Ultegra (Di2) ???
stormur
Thu Mar 23, 2017 10:42 am
stormur View the latest post
Users browsing this forum: No registered users and 2 guests
