It is currently Sun Oct 22, 2017 5:02 pm
Post new topic  Reply to topic  [ 13 posts ]
 Post subject: 11 speed disc hubs
PostPosted: Sun Jun 29, 2014 4:19 pm
I'm building up a Dirty Disco with the new 11 speed Shimano 105 as soon as the groupset is released. But I'm having issues finding decent wheels and would like to build some myself, but there are so few hubs to choose from.
I have found some novatecs for discs that are 11speed ready, but nowhere in europe where they can be purchased.
What other options are there?
I'm a relatively light guy weighing in at 72kg/160lbs and would like to buildsomething lighter than the Mavic Crossones that I might buy and use untill more hub choices start to appear.
Thank you.
 Post subject: Re: 11 speed disc hubs
PostPosted: Sun Jun 29, 2014 5:09 pm
Here you go
http://www.bikehubstore.com/product-p/mtb270.htm
There's sometimes a buggy.
One.
PostPosted: Mon Jun 30, 2014 3:15 pm
Thank you, I missed that one.
But are those two really the only options?
I wish shimao would release an 11 speed xt hub soon...
PostPosted: Mon Jun 30, 2014 4:16 pm
So Ultegra level is not good enough?
http://si.shimano.com/php/download.php?file=pdf/dm/DM-HB0004-00-ENG.pdf
PostPosted: Mon Jun 30, 2014 6:25 pm
Bikehubstore is not in Europe. You can purchase Novatecs from ebay (from Taiwan).
And Shimano 5800 is available on bike24.com and bike-components.de.
P.S I´m building also CX 11s wheels at the moment: 40mm tubs + Novatec 711/712 + Sapim Lasers/Race.
"Nothing compares to the simple pleasure of a bike ride"
Domane
Jamis Renegade Expert
Spark 900 RC
PostPosted: Tue Jul 01, 2014 12:51 am
What is the rear spacing? What is your budget?
What about Chris King R45's? White Industries? There are some options out there. Stan's has some pre-builts as well.
PostPosted: Tue Jul 01, 2014 2:11 am
Don't understand you guys.
Is there something that compels you to buy within the EU?
One.
PostPosted: Tue Jul 01, 2014 7:01 am
I have been thinking a bit about the issue of 11-speed disc hubs for a cyclocross bike with 135mm rear spacing:
What about a DT240s disc (MTB) hub with a 11-speed (road) freehub?
It is possible to buy the freehub alone to upgrade 10-speed road hubs to 11-speed. It will probably fit, but has any one tried it?
In meiner Kette fehlt kein Glied, wenn die Lust von hinten zieht.
PostPosted: Tue Jul 01, 2014 9:06 am
Ok, so to specify, the OLD on my frame is 135mm which means MTB spacing. The problem that arises is that since MTB hasn't really moved into 11 speed yet the 11speed mtb spaced hubs are only starting to come out. CK, WI and so on are unfortunately not within my budget.
The reason why I'm prefering to shop within the EU is because of the 30% that is added to the value in customs and import taxes when buying outside of the european union :?
TurboKoo wrote:
CX75
This is almost perfect and exactly why I asked in here :D I guess its down to novatec or shimano then.
I read that the 5800 group will also be available with hydraulics, so does that mean that I should just sit tight and wait for a 105 disc to come out? I have to admit that I have a small crush on mid-level shimano hubs because they are mile eaters.
@kame, I have no idea, but let me know when you try it!
PostPosted: Thu Jul 03, 2014 4:57 pm
kame wrote:
What about a DT240s disc (MTB) hub with a 11-speed (road) freehub? ...It will probably fit, but has any one tried it?
That is a good question and a task I intend to tackle next week with our Enve Twenty9 XC wheelsets which were built on DT240s 6-bolt hubs. Based on recent experience converting a Reynolds SDV66 road wheel, I think it should work as the 11-speed freehub included a new end cap so in the case of the disc brake hubs, I think it should be the axle spacing that makes it work and not the dimensions of the end cap.
Update - just perused the 2014 DT Swiss tech manual where I note that although the 240s disc mtb rear hubs have a driver for SRAM XD (11-speed), there is currently not an indication for 11-speed Shimano. So I placed a call to the tech department of a relatively well know US company that specializes in building wheels (play on words intended) 8) indicates that yes, you can use the 11-speed road freehub and end cap with the 135mm rear hubs. In our case, we are running DTs road thru axles so I would either have to drill out the 11-speed end cap or continue using the 10-speed caps which would spread the rear triangle something like ~1.5mm.
PostPosted: Sat Jul 19, 2014 6:32 pm
I'm getting a set built at the moment on Hope Pro2 Evo hubs, which Hope say are compatible with 11 speed. Had a set of their road hubs for a few years and they have been really good, so hopefully these will be the same!
PostPosted: Sun Jul 20, 2014 11:38 am
ms6073 wrote:
I'm using a DT Swiss 240 Centerlock hub that is set up for 10mm DT RWS with an 11spd freehub and have not spacing issues.
Gaulzetti Cabron Disc = (weight unknown)
Rock Lobster Team Tig SL Disc = (pending)
Sold: Ridley X-Night Disc = 7.80 kg | Ridley Noah FAST = 6.86 | Ridley Fenix = 6.74 | Raleigh HiLife = 7.46 | Fuji SST = 7.34 | Van Dessel FTB = 7.58
PostPosted: Tue Jul 22, 2014 3:27 pm
Thanks for that as I was not really wanting to drill out the 9mm QR end caps for the 10mm RWS Thru bolt.
There are no new unread posts for this topic. Fuji SL 1.1 Disc or Cannondale Synapse Hi Mod Disc or any other Disc Frame under 2000 dollars
vanmatthew
Fri Nov 18, 2016 9:34 pm
mpulsiv View the latest post
There are no new unread posts for this topic. Roval CLX50 disc or Dt Swiss ERC 1100 Dicut disc
in Everything wheels
Y26
Thu Mar 16, 2017 8:55 am
Delorre View the latest post
There are no new unread posts for this topic. Compatibility Question - 11 speed Crankset & 9 Speed running gear
pfnsht
13
463
Fri Aug 25, 2017 2:31 pm
goodboyr View the latest post
There are no new unread posts for this topic. Zipp 404 Disc Compatible W/ Venge Vias Disc?
Samklee15
Tue Nov 08, 2016 8:13 pm
Samklee15 View the latest post
There are no new unread posts for this topic. CAAD12 Disc Fram + New Campy Disc = Compatible?
NewYorkNick
19
2118
Sat May 13, 2017 8:17 pm
NewYorkNick View the latest post
Users browsing this forum: No registered users and 3 guests
