It is currently Wed Oct 18, 2017 2:42 pm
Which Gruppo?
Poll ended at Fri Jul 11, 2014 2:01 am
SRAM 71%  71%  [ 5 ]
Shimano 29%  29%  [ 2 ]
Total votes: 7
PostPosted: Thu Jun 26, 2014 2:01 am
Looking to rebuild my classic IF Planet X before this coming cross season. I am planning to run a 1x10 system but want to get opinions on whether to run SRAM or Shimano on the bike. I like both brands, so I don't have a big pull one way or the other.
SRAM build -
Rival shifters
Force FD
Force RD
Force crank
Shimano build -
Dura-Ace 7800 shifters
Ultegra FD
Ultegra RD
Dura-Ace 7800 crank
I would guess that the SRAM mix will be lighter, but the Shimano system might look better on the bike.
What are your opinions?
PostPosted: Thu Jun 26, 2014 2:02 am
I guess I should mention that since I am running 1x I won't be using those FDs afterall
PostPosted: Thu Jun 26, 2014 8:49 am
SRAM CX1 has a clutch which should help to keep your chain in place, without a chain guide. If you are going with Shimano I would definitely advise to go with a chain guide.
My Renovo R1 wooden bike project and the reason for my passion for all that is wood.
Check it out: the most amazing vintage Colnago, Merckx and Pinarello collection
PostPosted: Thu Jun 26, 2014 11:33 am
+1 on the Force CX1 rear derailleur
PostPosted: Thu Jun 26, 2014 12:24 pm
You can also use a X0 or X9 10-speed (type 2) short cage rear mech if you want a clutch.
PostPosted: Thu Jun 26, 2014 2:45 pm
unless you put the shimano mech in high tension mode
http://crossjunkie.blogspot.co.uk/2014/ ... et-up.html
Loads of people in the cross league i race in use no clutch mech, no chain guide and a narrow/wide chainring with no chain drops.
PostPosted: Fri Jun 27, 2014 1:12 am
I'm running campy 1x10, record crank, chorus rear mech and shifters.
Turns lots of heads!
PostPosted: Mon Jun 30, 2014 5:48 pm
SRAM CX1 is 11spd isn't it?
Pegoretti Responsorium, Parlee Z5i, Donhou Commuter, 1946 MacLeans Featherweight L'Eroica!, 2x MTB 'dales
There are no new unread posts for this topic. Niner RLT9 Steel DI2 build
jeroenfl
Wed Oct 18, 2017 2:29 am
grover View the latest post
There are no new unread posts for this topic. Niner RLT Steel 2017 Gravel bike build
leicaman
Fri Jul 14, 2017 4:23 pm
gravity View the latest post
There are no new unread posts for this topic. Planet X - worth it?
sipowicz
13
1824
Sat Jun 03, 2017 5:09 pm
colster View the latest post
There are no new unread posts for this topic. Planet-X Clothing
sanrensho
Mon Oct 24, 2016 10:09 am
icenutter View the latest post
There are no new unread posts for this topic. Rear mech Hanger for FM-066/Planet X RT 80/Viner Mitus
Svetty
Fri Aug 11, 2017 5:28 pm
jrccomponents View the latest post
Users browsing this forum: No registered users and 6 guests
