It is currently Tue Jan 16, 2018 10:30 am
Post new topic  Reply to topic  [ 9 posts ]
PostPosted: Fri Jun 20, 2014 4:49 pm
I've got some 36h hubs that I'd like to re-use for a new bike, but I'm not doing too well finding some decent 700c/29er rims to lace them up to. I could go 24h and skip some hub holes (that's how they're laced now) but am not sure if that would hold up to the abuse (though it has been fine for XC to date). They are disc hubs, and I'm planning to use the wheels for commuting on our potholed UK roads with a bit of weight on the rack when required. Tires probably up to 40mm depending on what the frame fits.
Any suggestions?
PostPosted: Tue Jun 24, 2014 12:12 pm
light-bicycle 27mm hookless carbon, atleast. maybe even wider
PostPosted: Wed Jun 25, 2014 4:25 am
Clincher or tubular rims?
To fit a 40 mm, you can get the DT TK540's. They are box section, immensely strong, beautifully made, and not unreasonably priced.
Kinlin 300's are available in 36 hole, but I can't say I'd put a 40 mm tire on them. They're narrow rims, but for cross they are light and have a deep enough section that they won't load up too much with mud.
Frankly, in clinchers, you can get some screaming deals on weird colors (frost blue, lime green, hammer tone, etc.) in Velocity Deep V's in 36 hole on eBay. Ben's Cycle is clearing out a bunch of colors at about $27 a rim.
In tubulars, Kinlins are available in 36 hole. Not too many choices for tubulars, though, and the better tubular rims like the Hed Belgium tubular and any of the carbon fiber rims don't come in 36.
I was a 36-hole holdout for a while, but honestly, they are like nailing your cleats to your shoes -- the equipment is all disappearing and they are really becoming obsolete. Sooner or later, you just want to get some new hubs in 28 or 32. Rims and spokes are so much better these days that the wheels will be just as solid as 36-spoke wheels with the older poorer rims.
PostPosted: Wed Jun 25, 2014 4:02 pm
Should have said clinchers and disc brakes, sorry.
I'm trying to avoid spending yet more on hubs, but perhaps I should think some more about it...
PostPosted: Thu Jun 26, 2014 9:06 am
I'm running 36h Open Pro rims for training, touring/gravel and some commuting/errands duty, on shimano disc hubs. Been using various tyres from 23mm road to 32mm CX ones so far. They get the job done.
If I was building the set these days, I would probably give the H Plus Son TB14 a closer look. Slightly wider, and the beautiful finish stays immaculate with disc brakes. Shallow rims will lots of spokes ride great.
PostPosted: Thu Jun 26, 2014 10:06 pm
Archetypes and TB14's are the new Open Pro. They'll fit anything from 23 to 40mm tyres comfortably and will build into a super strong wheel. Open pro is so narrow that anything bigger than 28's starts to create a lightbulb shape of the tyre which translates into poor cornering with low tire pressure.
PostPosted: Fri Jun 27, 2014 5:08 am
Velocity offer a number of rims with 36h drilling. Blunts, A23 etc
NoTubes FlowEX comes in 36h.
Pacenti offer a number of 36h rims. If it were my money and I could track down a set of TL28 rims easily enough, I think I'd pick these.
PostPosted: Fri Jun 27, 2014 6:05 pm
Disc brakes and road wheel sizes open up some of newer mountain rims. I certainly wouldn't want to ride a smaller tire on those rims (anything under about 28 mm), but if you want a big fat casing on there, just get a 36-hole mountain rim without braking surfaces in the same diameter. Do note that some of those rims get VERY wide, and you may have clearance issues, but if you're talking 42 mm tires, I figure the rim isn't going to be your problem.
PostPosted: Tue Jul 22, 2014 11:22 am
Looks like the top options are the Velocity Blunt SL and Pacenti TL28. I'm not too worried about the top sizing, but my thoughts this morning are around the minimum tire size for when I want to take it quick on the road (28mm?). Have emailed both companies to find out their take on it.
There are no new unread posts for this topic. Decent fork options
TheDarkInstall
Tue Mar 28, 2017 4:32 am
froze View the latest post
There are no new unread posts for this topic. Cheap clip-on TT bars with decent adjustment?
Shrike
Tue Dec 19, 2017 2:19 am
jlok View the latest post
There are no new unread posts for this topic. Why are most integrated bar/stem combos so heavy?
morganb
13
913
Tue Jan 09, 2018 5:21 pm
Chans1ee View the latest post
There are no new unread posts for this topic. Stiffness difference between super light carbon rim and very heavy alu?
in Everything wheels
Alexandrumarian
Thu Nov 30, 2017 9:48 pm
Alexandrumarian View the latest post
There are no new unread posts for this topic. Anyone seen this on rims?
Bergwerk
Sun Jan 14, 2018 12:21 am
bm0p700f View the latest post
Users browsing this forum: No registered users and 3 guests
cron
