It is currently Mon Jan 22, 2018 5:37 am
Post new topic  Reply to topic  [ 11 posts ]
 Post subject: PF30.. which to choose?
PostPosted: Fri May 16, 2014 10:37 pm
i'm running a XO crank and it came with the SRAM PF30 BB. but with my frame, they included a FSA PF30 BB.
The FSA is lighter compared to the SRAM... but which to choose to be more reliable or are all BB relatively the same?
PostPosted: Sun May 18, 2014 8:29 pm
I've found they vary a lot, especially in propensity for creaking. I've had superb experiences with several of the King PF30 BB's -- no creaking, no installation problems, absolutely invisible. The SRAM have had more problems, at least in our hands. The FSA ditto. SRAM does make an adapter that lets you thread a regular English BB into the adapter that's quite nice and sidesteps the whole question. The Praxis is also really nice -- it threads together to lock firmly in place, and you can overhaul it really well -- but the shell doesn't have room for Di2 cable routing on some frames. If you want a simple solution, the King has been perfect in the hands of everyone I've talked to. It's one of the more expensive ones, but it's like a King headset -- you pay and forget about it.
PostPosted: Mon May 19, 2014 3:54 am
thanks 11.4. the FSA was 37g vs. SRAM was 41g... so went with FSA. will keep the SRAM for backup if i get creaking issues down the road.
side question though.. when you install the bb.. do you lube? i've read some reviews where they suggest to press in dry to prevent creaking, while others like parlee would recommend using loctite with their BB on the frame.
PostPosted: Mon May 19, 2014 7:15 pm
I've heard both ways but the people I trust the most said to lube it. I've done a couple dozen team bottom brackets and half a dozen others (mostly my own). I've lubed all of them, used the King BB, and have yet to experience a creak.
PostPosted: Mon May 19, 2014 10:19 pm
11.4: thats' good to hear.. cuz i lubed it too and it's pressed in along with crankset installed. now the only issue on my cross is i can't use my old DA7800 wheelset cuz the hub doesn't work with the XO cassette i'm running. :( need to shop for new wheelset.. any suggestions?
PostPosted: Tue May 20, 2014 6:52 am
That doesn't make sense... Why doesn't a 10 speed wheelset work with a 10 speed cassette?
PostPosted: Tue May 20, 2014 7:06 am
Jooo... here is why. There is this rise on the hub teething that preventing the XO cassette from going in.
Sent from my SGH-M919 using Tapatalk
PostPosted: Tue May 20, 2014 3:49 pm
Ahh yes, I forgot about the 1st gen aluminum freehub.
If you'd like to use your 7800 wheels and you're willing to give up a bit of range, the Ultegra 12-30 should fit if you exclude the normal spacer.
PostPosted: Tue May 20, 2014 5:12 pm
Jooo.. yea I thought about doing that... but at this point probably just get farsport cx wheelset instead.
PostPosted: Wed May 21, 2014 6:56 pm
Those hubs were a big stumble for Shimano. Their earlier and later hubs were great. Those not only had idiosyncratic cassettes, but they also tended to break easily. That's why you see them selling for dirt cheap. Don't invest in anything to further the life of those hubs. I'd plan to bite the bullet and get better hubs. If you want to stick with 10-speed cassettes or use the 10-to-11 conversion cassettes that are starting to appear, I'd recommend the 7900 hubs. They are solid and long lasting and, because of the 10-speed thing, selling for cheap. Other than that, I'd just buy Chris King or White Industries in 11-speed. The Whites are very competitively priced and have superb engineering. Cosmetically not quite as nice as Kings but from an engineering standpoint, possibly even a bit better.
PostPosted: Wed May 21, 2014 9:45 pm
11.4: thank you. yea.. guess it's probably worth it in the long run to invest in a new set of wheels instead of just replacing the hub on this 7800 wheelset huh?
There are no new unread posts for this topic. switching from pf30 24mm to pf30 bb30 cranks ??
Allen254
Tue Nov 21, 2017 8:02 am
mrlobber View the latest post
There are no new unread posts for this topic. New sram pf30 design
NiFTY
Tue Jul 25, 2017 2:36 am
uraqt View the latest post
There are no new unread posts for this topic. PF30 to 24mm BB with removable bearings
mike001100
13
1089
Sun Oct 29, 2017 12:21 am
IrrelevantD View the latest post
There are no new unread posts for this topic. PF30 shell diameter discrepencies
Flapmeat
Wed Nov 01, 2017 1:00 pm
sungod View the latest post
There are no new unread posts for this topic. PF30 frameset: best BB/ spindle crankset options ?
LouisN
Sun Nov 26, 2017 2:05 pm
vejnemojnen View the latest post
Users browsing this forum: No registered users and 3 guests
