Is SOH important?
addictR1
by addictR1
On my Scott Addict R1, the stand over height is 756 and a frame I'm looking at the soh is 786.
The top tube reach, and seattube all matches my Scott if just a bit off.
Should I be concerned? Would this mean my seatpost needs to be much lower compared to my Scott?
Sent from my SGH-M919 using Tapatalk
addictR1
by addictR1
anyone? or is SOH just not as important?
efeballi
by efeballi
Saddle height does not change with standover height.
If your undercarriage is now close to the top of te Addict's top tube, you'll have trouble riding the new frame. You should have at least 3cm of clearance with the Addict to be able to ride the other frame.
SHUT UP LEGS
2015 Giant Propel Advanced
2013 KTM Strada mod. GOT IT BACK!
2011 Pinarello Dogma 60.1(loaner)
2011 Scott SUB 45(sold)
Politecnico di Milano Ingegneria Meccanica
stoney
by stoney
You measure your saddle height from the center of the bottom bracket to the top of your seat. SOH has nothing to do with seat height.
Juanmoretime
Administrator
by Juanmoretime
Its only important if your inseam is very close to the stand over height. Don't want to smash your "equipment" on the top tube in a fast dismount. Saddle height is a measured from the bottom bracket center or pedal start. So if seat tube length and seat post can get you the same height as your current set up your good.
RESIDENT GRUMPY OLD MAN.
ms6073
by ms6073
stoney wrote:SOH has nothing to do with seat height.
Yes, and while saddle height will remain the same, and while unlikely, if some/all of the increase in SOH is due to a taller bottom bracket, then that could make for a significant difference when it comes time to dismount/remount.
