It is currently Fri Jan 19, 2018 4:50 pm
Post new topic  Reply to topic  [ 7 posts ]
PostPosted: Tue Apr 22, 2014 5:23 am
... With SRAM XX1 group set. Question is, instead of the grip style trigger, can I use the SRAM bar end type of shifter instead?
Sent from my cm_tenderloin using Tapatalk
PostPosted: Tue Apr 22, 2014 6:32 am
Could you not just use cx1?
PostPosted: Tue Apr 22, 2014 6:33 am
But pretty sure roadaand mtb 11 speed is compatible
PostPosted: Tue Apr 22, 2014 6:44 am
Apparently they have a differentpull ratio :(
PostPosted: Wed Apr 23, 2014 3:43 am
after doing some digging.. heard from some LBS that the sram bar end may or may not work with the XX1 group... :( waiting for SRAM to reply with positive reply.
PostPosted: Wed Apr 23, 2014 5:19 am
The SRAM road 10 and 11 speed shifters and derailleurs are interchangeable in terms of cable pull. This is also interchangeable with SRAM mtb 10 speed.
eg. 11 speed road shifter works with 10 speed road derailleur or mtb derailleur to shift across 11 cogs. There may be some very minor differences in cage width (wider for 10 speed chain) but in the real world it works without issue with an 11 speed chain.
XX1/X01 11 speed uses a different cable pull which is only compatible with the XX1/X01 trigger or gripshift.
If you want to use SRAM road levers (or aero bar levers) whether they be 10 or 11 speed, with a mtb derailleur you should use the 10 mtb speed components. If it is chain retention you want then an x9 or x0 type 2 works well (this is my setup with double ring). If you're only wanting to use a single ring then use the x01 10speed rear derailleur (sram make three versions of x01 - 11 speed, 10 speed and 7 speed DH).
These will then shift across however many cogs the shifter is designed for. Note that the derailleur is designed for cassettes up to 36 tooth so will sit along way away from closer range cassettes. If you want to use a closer range cassette use the xo DH. This is not a type 2 derailleur. However it has a higher spring tension as stock for chain retention and a shorter paralellogram designed to follow a close range cassette (maximim 28 tooth).
There are currently no derailleurs that work with road shifters that accomodate the xx1/xo1 10-42 cassette. Due to the different 11 speed spacing versus 11 speed road cassettes and due to the increased b-tension requirement.
If that's confusing tell me the setup you want to run and I'll let you know if it'll work.
PostPosted: Wed Apr 23, 2014 5:24 am
Thanks for the detail info. Maybe easier to just build another road bike.. lol
Sent from my SGH-M919 using Tapatalk
There are no new unread posts for this topic. bike build questions...
izz012
26
1868
Wed Oct 04, 2017 11:21 pm
hcgaloi View the latest post
There are no new unread posts for this topic. Shorter Bike build
ed325
Thu Nov 02, 2017 4:26 pm
ed325 View the latest post
There are no new unread posts for this topic. Looking to build a 12-lbs climbing bike
Noctiluxx
19
1767
Mon Aug 07, 2017 6:35 am
tonytourist View the latest post
There are no new unread posts for this topic. My first road bike and my first build - UPDATE
Mtek
25
3071
Mon Nov 27, 2017 6:01 am
Mtek View the latest post
There are no new unread posts for this topic. Lightweight TT bike build ideas
tomcooling25
13
1179
Fri Sep 01, 2017 10:30 am
jever98 View the latest post
Users browsing this forum: No registered users and 1 guest
