It is currently Tue Jan 23, 2018 5:15 pm
Post new topic  Reply to topic  [ 5 posts ]
PostPosted: Thu Feb 20, 2014 2:18 pm
So I finally got my gravel road ride finished and may be able to get out soon. What pressure should I run the tires at? This will be on hard packed snow for now and later on hard packed gravel roads with no mud or grass. Basicly rail trails and such with some climbs as well as descents and corners.
PostPosted: Thu Feb 20, 2014 2:36 pm
Whats your weight?
CX RACE 12.12.15 http://www.cx-sport.de/content/cyclocro ... cup-cochem
PostPosted: Thu Feb 20, 2014 2:40 pm
I am at about165 pounds or about 75 kg.
PostPosted: Thu Feb 20, 2014 3:30 pm
On snow try 28psi out back and 26 up front. Go down 2psi in each if you finish more than 2hrs riding without having bottomed them out. If you bottom out more than 3x in a ride add 2 or 3 psi. On gravel roads I would suggest to start 4 psi higher.
Keep in mind that pros at your weight racing these tires run down to 18psi. And excluding sharp-edged rocks, you aren't going to get a flat from bottoming out the tire against the rim (no pinch flats/snake bites.)
Do be careful cornering on damp/greasy asphalt, as the transition from file to knobs is not so smooth on a hard slick surface. I just laid the CX bike down on some fast descending in a decreasing radius turn yesterday, and my shoulder and knee can still feel it.
PostPosted: Thu Feb 20, 2014 3:54 pm
Ok, I will give that a try. With a thaw coming I should be able to get out within the next few days. I just have to wait till some of this snow gets out of the way. There is over a foot in the area that I like to ride at the present time.
I am really looking to get back on a bike after this long cold winter here in PA.
There are no new unread posts for this topic. Hutchinson sector 28 tubeless... harsh ride , pressures ?
racesnake
Mon Dec 11, 2017 4:36 pm
morganb View the latest post
There are no new unread posts for this topic. Grifo valve extension advice
alanmclean
Thu Oct 05, 2017 7:30 pm
alanmclean View the latest post
There are no new unread posts for this topic. Can I buy this tubular wheel and fix it?
in Everything wheels
Sm0421
Tue Sep 19, 2017 3:46 am
LouisN View the latest post
There are no new unread posts for this topic. Tubular suggestion
Luca79
21
2383
Thu Apr 20, 2017 8:57 pm
DaReef View the latest post
There are no new unread posts for this topic. tubular vs clincher
proudCAAD12
7
1281
Thu Jun 01, 2017 3:35 pm
shineplus View the latest post
Users browsing this forum: No registered users and 2 guests
