It is currently Thu Jan 18, 2018 10:59 pm
Post new topic  Reply to topic  [ 11 posts ]
PostPosted: Mon Feb 03, 2014 9:35 pm
Hey there!
I did my homework (used the search first), but couldn't find the answer...
If it has already been answered, than i'm sorry.
Combination: Shimano Ultegra 6800 tubeless ready wheelset + open tubular (Challenge Grifo XS Open Tubular) cx tires.
Question: do i need to use rim tape for this combo? The inner surface of the rim is originally smooth, and there are no holes for the spokes.
Thanks for any advices!
PostPosted: Tue Feb 04, 2014 10:53 am
Administrator
No holes requires no tape. You might need a build up of tape if you're going tubeless to fit the tire tight enough to seal.
RESIDENT GRUMPY OLD MAN.
PostPosted: Tue Feb 04, 2014 11:29 am
Thank you!
PostPosted: Tue Feb 04, 2014 11:32 am
As above. Those tyres are not suitable for tubeless conversion though, as skinwalls are too porous according to people who know more than me:
http://www.cxmagazine.com/going-tubeles ... mendations
Blog: http://thesetbackpost.com/
PostPosted: Tue Feb 04, 2014 1:00 pm
Yeah, i read about that. Thank god, i only plan to use it with inner tube, as a non tubeless wheelset. Thanks for the heads up though!
PostPosted: Tue Feb 04, 2014 1:12 pm
Remember that the Ultegra wheelset is for road tubeless. Which is an entirely different standard from "regular" (MTB) tubeless (as is found on the Stan's rims).
Cannondale F-Si Team 2015
Cannondale F29 Team 2014
Cannondale F29 Carbon 1 2013
PostPosted: Wed Feb 05, 2014 7:17 am
Challenge Tires are often difficult to ride tubelss#
Try!
Depending on the Rim.
Dont use the if there is no tight fit.
CX RACE 12.12.15 http://www.cx-sport.de/content/cyclocro ... cup-cochem
PostPosted: Thu Feb 06, 2014 10:47 am
TUBULAR cannot be ridden onTUBELESS rims. In order to run tubular you would need to buy tubular wheels
PostPosted: Thu Feb 06, 2014 10:51 am
Challenge calls its clincher/open tires
"Open Tubular"
PostPosted: Wed Feb 19, 2014 10:01 am
Hi all,
Challenge open tires are handmade tires and follow the technology of tubular. They are designed to be used with tubes and with traditional ETRTO rims.
Tubeless is a recent development that still is not set or defined for the road side. There are still too many issues to be resolved and standards to be set before it
will takeover the clincher market. If it ever will.
To run an open as tubeless is very difficult, not much for the casing that is pours and this with simple sealant is resolved and that in any case the system requires
but are the beads shape and size that do not seal and hold. They work with 6 bars 87psi max on the road on some tubeless wheels but the hooks and internal sizing
of these wheels do not match our bead shape and the tire can blow of.
We therefore do NOT recommend tubeless systems with open tires.
From this year we have the Grifo 120tpi, this is a clincher nylon based and is more suitable for tubeless systems. Road side Fore 120tpi can be used also.
:beerchug:
PostPosted: Fri Feb 21, 2014 10:04 am
It would be very nice to see a Challenge tubeless cross tire. But you should definately go for the mountain bike tubeless-ready kind of tire. This would also be nice, such that we can use our MTB wheels on our cross bikes.
Road tubeless is another standard, and mainly for tires that need high pressure AFAIK.
There are no new unread posts for this topic. Installing Challenge Open Tubular/Clincher tyres.
in Everything wheels
SteveW4130
10
1628
Wed Feb 08, 2017 2:15 pm
SteveW4130 View the latest post
There are no new unread posts for this topic. Ultegra 6800 brake feel
mvcap
23
2505
Wed Mar 22, 2017 12:45 pm
redna12 View the latest post
There are no new unread posts for this topic. 2014 Cannondale Supersix Evo : Ultegra 6800 : 7.4 KG
Alpine318is
Mon Jan 23, 2017 7:34 pm
Alpine318is View the latest post
There are no new unread posts for this topic. Ultegra 6800 Reach Lever Screw broken
probertsqbe
Tue Feb 14, 2017 12:09 pm
probertsqbe View the latest post
There are no new unread posts for this topic. Trek BB90 + creaking Ultegra 6800 hollowtech 2. Anyone like a mystery?
alcatraz
11
1005
Fri Sep 08, 2017 3:27 pm
kwakekeham View the latest post
Users browsing this forum: No registered users and 4 guests
