It is currently Wed Oct 18, 2017 3:23 am
Post new topic  Reply to topic  [ 51 posts ]  Go to page Previous 1 2 3 4 Next
 Post subject: Re: Sram CX1
PostPosted: Tue Mar 11, 2014 5:50 pm
Officially launched:
http://www.sram.com/sram/road/family/sram-force-cx1
PostPosted: Tue Mar 11, 2014 10:45 pm
Looks nice :)
But no levers for hydraulic brakes? Shame on you, SRAM... That's a huge fail IMHO.
Cannondale F-Si Team 2015
Cannondale F29 Team 2014
Cannondale F29 Carbon 1 2013
PostPosted: Tue Mar 11, 2014 11:54 pm
Interesting that SRAM makes a CX product of its own. Shimano, in contrast, tends to fill the gaps with single product releases (e.g. R series compact cranks, CX FD and cranks).
Is there any technical reason why SRAM couldn't do the same? Totally seeing the need for a product line on the MTB side with the incompatible hub, but for the CX, isn't really just crank and RD, and maybe a shifter-less left brake needed?
PostPosted: Wed Mar 12, 2014 12:40 am
I believe they're planning on offering hydraulic compatible levers as well, but of course sorting out the big recall probably put a huge dent in getting those to market at the same time as the rest of the group.
PostPosted: Wed Mar 12, 2014 2:51 am
This really is just a fill-in few components to make a CX1 group. New RD works with any Exact Actuation lever (10/11spd mechanical OR Hyrdo) - the CX1 shifters are just Force 22 with different logos and shifter guts removed from one side.
And CX1 crank is exactly the same as the Force crankset with a different chainring. They just added CX1 logos like the shifters.
As for chain and cassette they ARE just Force 22.
So buy the CX1 RD and chainring, pair with whatever 110bcd crankset and SRAM 10/11spd shifter/cassette/chain you want and you are away.
Start flat out ... then pick the pace up halfway
PostPosted: Wed Mar 12, 2014 9:43 am
I believe the groupset is branded as "Force" because SRAM is planning on releasing a "Red" version 2015 when they launch hydraulic.
PostPosted: Mon Mar 17, 2014 7:57 pm
Does anyone know if online retailers are selling these yet?
PostPosted: Tue Mar 18, 2014 11:52 am
They say it will come in July.
CX RACE 12.12.15 http://www.cx-sport.de/content/cyclocro ... cup-cochem
PostPosted: Tue May 20, 2014 12:39 am
July, for real?
I'm really liking this group
PostPosted: Tue May 20, 2014 7:02 pm
Shop Wrench
cx1 will be available within this or the next week here in the states. I would imagine you would see it just as soon in AUS!
PostPosted: Wed May 21, 2014 3:27 am
Sweet, thanks for the info.
I'm not traditionally a SRAM guy, but 1x11 is quite innovative. I'm planning to try it out on a do it all gravel grinder/road bike.
PostPosted: Tue Jun 17, 2014 10:34 am
Just got my cx1 38t chainring the other day, 72g w/o hardware. Rd should drop in any day now =)
When i first started building my cx i went full Force22, now i need help gutting my left shifter. Found an old howto on cxmagazine but its for old force, Anyone has any ideas?
PostPosted: Tue Jun 17, 2014 11:03 am
You could also sell the left shifter, and get one of the empty SRAM shifters, a CX1 or a SRAM 900 single speed lever: http://www.sram.com/sram/road/component/shifters
(Assuming you are running canti brakes).
PostPosted: Wed Jun 18, 2014 1:10 am
To remove guts from Force 22 left shifter (working from memory)
- remove shifter hood
- remove brake lever by removing circlip on pivot pin and pushing pivot pin out
- remove shift internals cover on inside of shift body by removing 3 screws
- on outside of shift body there is one screw stopping a metal rod that runs through the shifter, remove it and push metal rod out
- you should then be to able to wiggle out the shifter spool/spring
- there is a rod that the shift lever pivots on held in by a circlip. remove circlip, rod and shift lever
- MAKE SURE to replace rod that runs through shift body and screw that retains it on the outside of shift body. This rod greatly stiffens the shift body, you're likely to snap/crack the shift body if you leave it out.
- reinstall brake lever and shifter hood
Grover's Grumblings
Grover's Garage
PostPosted: Sun Jun 22, 2014 4:01 pm
Thanks, I fiddled a bit got the internals out just the way you described
There are no new unread posts for this topic. Which power meter: Sram Red + Stages or Quarq Dzero Sram
[ Go to page: 1 2 3 4 5 ]
Shrike
70
9165
Sat Apr 08, 2017 10:20 am
JackRussellRacing View the latest post
There are no new unread posts for this topic. Sram red 52/36?
commendatore
Mon Jul 03, 2017 9:44 pm
Alpine318is View the latest post
There are no new unread posts for this topic. Sram Red Brakes
trilocus
Mon Aug 21, 2017 8:39 am
trilocus View the latest post
There are no new unread posts for this topic. SRAM Red RD repair
thePrince
Sun Aug 27, 2017 4:07 pm
sungod View the latest post
There are no new unread posts for this topic. Sram red leaver pin
SNUGSHIP
Tue Apr 18, 2017 11:00 pm
SNUGSHIP View the latest post
Users browsing this forum: No registered users and 2 guests
