condor terra x build advice
Jamesclowes
by Jamesclowes
Hi there,
I have just bought a new Condor Terra X frame set and am building it up as a winter commuter/trainer with parts from another bike. However, I have never dealt with internal cabling and hence have a query from anyone that has built this or a similar bike up.
Basically, does the cable outer go all the way through the frame? On similar Condor Terra X builds I have seen cable ferrules sticking in each of the gear cable entrances. Hence I would assume that only the cable inner runs through the frame.
If anyone could put my mind at rest by letting me know that would be much appreciated.
Thanks,
James.
euan
by euan
Call Condor?
"Step forward the climber and all those who worship at the altar of lightness" - R. Millar
JackWalk
by JackWalk
Jamesclowes wrote:Hi there,
Thanks,
James.
Only the inner goes through the frame with internally routed cables
hurricanejosh
by hurricanejosh
Thanks,
James.
no, on the condor's the housing is routed through the frame as well. probably to keep the mud out of your housing
