It is currently Thu Jan 18, 2018 3:22 am
Post new topic  Reply to topic  [ 20 posts ]  Go to page Previous 1 2
PostPosted: Tue Jan 28, 2014 9:58 am
A drilled stem is indeed the lightest solution. That said, the Tektro/TRP fork mounted cable hanger is also pretty light and does a great job at reducing brake shudder.
My Renovo R1 wooden bike project and the reason for my passion for all that is wood.
Check it out: the most amazing vintage Colnago, Merckx and Pinarello collection
PostPosted: Mon Feb 24, 2014 4:34 pm
ive used this.
PostPosted: Mon Mar 03, 2014 9:58 pm
MasterOMayhem wrote:
ive used this.
May I ask where you purchased this from?
PostPosted: Mon Mar 03, 2014 10:19 pm
I would like to know too :)
Cannondale F-Si Team 2015
Cannondale F29 Team 2014
Cannondale F29 Carbon 1 2013
PostPosted: Sat Mar 22, 2014 4:14 am
It is actually a rear cable hanger designed for being used with the seat binder bolt, it i made by Tektro:
http://www.amazon.com/Tektro-Rear-Cable ... B001CJV94O
I have been using this setup for 3 or 4 years now, it is still going strong and working well. I had to modify the top loop of the hanger a bit so that it didn't interfere with bar on Thomson stem. It tends to pull a bit to one side because its hard to center, so I had to slightly compensate by increasing the spring tension on my Neo-Retro's to keep the pads centred on rims, easy fix though!
Has a pretty clean/minimal look in the end. I ended up going this route due to lack of steer tube to run a normal hanger. My options were, drill out stem (wasn't quite prepared to do that), or run one of those heavy and kind of ugly crown mounted ones. This was only $2-$3 to try out, so I went this route and it worked.
There are no new unread posts for this topic. Lightest crank + bb solution for a bbright frame (like the s5)
alcatraz
9
690
Wed Nov 08, 2017 5:03 am
prendrefeu View the latest post
There are no new unread posts for this topic. canti vs disc
stormur
39
2828
Tue Dec 26, 2017 9:04 pm
Multebear View the latest post
There are no new unread posts for this topic. OSBB to BSA - what's the best solution?
ak47
Sat Mar 18, 2017 4:31 pm
lovemyway View the latest post
There are no new unread posts for this topic. Sram Red 22 Lazy Rear Shifting Solution
Mr.Gib
Wed Oct 04, 2017 11:06 pm
asiantrick View the latest post
There are no new unread posts for this topic. Litespeed T1 hanger question
addictR1
Sun Jul 09, 2017 9:07 pm
addictR1 View the latest post
Users browsing this forum: No registered users and 6 guests
