Post new topic Reply to topic  [ 11 posts ]
PostPosted: Sun Jan 15, 2006 7:58 am
I am just about to get my new frame painted and should have it back this week but do not have brakes for it yet. What would you suggest on the light side and on the less expensive side of things. Not sure if I am going to build this light or just for winter riding. Thanks
 Post subject:
PostPosted: Mon Jan 16, 2006 2:34 am
I have Alu spookys and love them. They are pretty easy to set up, use standard pads and are relatively light and inexpensive.
 Post subject: shimano br550
PostPosted: Fri Feb 03, 2006 11:57 am
Easy to set up.
2 minute pad changes.
cheap.
work great.
 Post subject:
PostPosted: Fri Feb 03, 2006 10:41 pm
im using the paul neo retro/touring combo. i like them alot. especially that you can dial in toe in due to the cartridge type pads. theyre not the cheapest though.
PlusOneLap.com: Everything Cyclocross
 Post subject:
PostPosted: Fri Feb 03, 2006 10:50 pm
I don't know what you budget is. Spooky's are very good but they cost more. On my trainingbike I got the Avid Textro and I like them.
You shouldn't buy the Radius, they are worse:(. I will replace them for Spooky carbon probably(Thnx to Timo;)
PostPosted: Sun Feb 05, 2006 12:07 am
Well, I use the froglegs with 4ZA break pads for carbon wheels. I would like to buy Spooky Carbon Cantis, but it seems to be very difficult to get them in Germany... :noidea:
 Post subject:
PostPosted: Sun Feb 05, 2006 12:10 am
This site does not work: http://www.plusonelap.blogspot.com/ :(
 Post subject:
PostPosted: Sun Feb 05, 2006 2:23 am
yeah i know the server is down right now. im a little pissed.
 Post subject:
PostPosted: Mon Feb 06, 2006 11:37 pm
Well I finally got my new cross frame, forks and brakes. I picked up a 54cm Redline Conquest and fork (to be replaced with a carbon fork) and ended up getting a free set of TEKTRO Oryx Canti Brakes with some TEKTRO Carbon cross levers (paid for the levers). Other parts going on the bike will be a FSA Gossamer MegaExo Compact crank. Crank Bros Candy SL pedals, full ultegra 9 speed, Thomson seatpost, Syntace stem, Pazzaz carbon/aluminum bar and most likely some Ritchey Pro DS wheels. Most of the parts are spare parts from other bikes that I have been building up. I will post some pictures when it is done. Hopefully not a tank and would like to get it around 20 or under.
 Post subject:
PostPosted: Tue Feb 07, 2006 10:43 am
the original tektro brakepads dont last very long , but brake very good on all of my rims
since two days i am ridingt mini v-brakes
first impresion : perfekt
weigt : a little more
handpower very low
much more space between pads and rim , as on long v-brakes
very fast adjustable
elmar
 Post subject:
PostPosted: Tue Feb 07, 2006 10:46 am
handpower very low
elmar
Users browsing this forum: No registered users and 5 guests
There are no new unread posts for this topic. upgrade Sram Red 2011 Brakes to the new Sram Red 2012 brakes
poppiholla
Wed Jul 04, 2012 10:20 am
MarkThailand View the latest post
There are no new unread posts for this topic. Good day!
nighthunte29
Thu May 24, 2012 3:06 pm
yrodriguez317 View the latest post
There are no new unread posts for this topic. Ritchey Biomax bar any good?
in Cyclocross / Touring
limba
Mon Nov 12, 2012 9:22 pm
peterf1963 View the latest post
There are no new unread posts for this topic. good allround cross tub
brearley
15
1911
Sun Nov 18, 2012 10:36 pm
toride View the latest post
There are no new unread posts for this topic. Bontrager saddles... any good?
blantonator
Thu Jul 19, 2012 6:50 am
Brandonnie View the latest post
It is currently Thu May 23, 2013 11:38 pm
