It is currently Sat Jan 20, 2018 12:05 pm
Post new topic  Reply to topic  [ 4 posts ]
 Post subject: Challenge Chicane
PostPosted: Thu Nov 07, 2013 9:07 pm
Any experience with Challenge Chicane ?
I got a set today and was wondering whether they would work in (light) mud, wet conditions. I have no experience at all with this kind of semi-slick tubulars
 Post subject: Re: Challenge Chicane
PostPosted: Fri Nov 08, 2013 4:17 am
The size knobs are aggressive enough that at low pressure you should get good traction in the corners. Braking might be a little more cautious in a straight line though since they lack the center knobs. Looks like the perfect tire for Chicagoland.
PostPosted: Fri Nov 08, 2013 7:47 am
From racing the XS in the wet I would expect the Chicane to work in a lot of conditions. Wet or muddy corners should be ok. You'll get some squirm and float around a bit on genuinely muddy straights and downhills.
The key though to remember is that you won't be pedaling up anything muddy. Ramps, short 'run-ups', extended climbs. If they deteriorate beyond wet grass to where you can only see mud (ie. no longer any underlying grass), and tire lines become visible in the mud, you'll be getting off to run.
Good luck. I have a feeling that the tires will be great!
PostPosted: Mon Nov 11, 2013 6:21 pm
I used the set for yesterday's race, in wet conditions.
I'm very happy with the tires. The grip is amazing while cornering
There are no new unread posts for this topic. Challenge vulcanised tires, tubeless?
Frankie - B
Fri Jan 19, 2018 10:52 am
mattr View the latest post
There are no new unread posts for this topic. What do you think of Zwift's 'Hunter's Challenge' training plan?
in Training
Shrike
7
1870
Wed Mar 22, 2017 4:22 am
ms6073 View the latest post
There are no new unread posts for this topic. Best place for Challenge Limus 33 tubular online
LouisN
Fri Oct 06, 2017 11:26 am
LouisN View the latest post
There are no new unread posts for this topic. Installing Challenge Open Tubular/Clincher tyres.
in Everything wheels
SteveW4130
10
1631
Wed Feb 08, 2017 2:15 pm
SteveW4130 View the latest post
Users browsing this forum: No registered users and 5 guests
cron
