Mudguards for CX disc
Beancouter
by Beancouter
Building up a disc cx for cx and bad weather duties. The frame doesn't have any fixings or a drilled brake bridge in fork it at rear.
Any thoughts on mudguards - the only ones I can find are raceblade xl's but not sure if they are a bit short?
mattr
by mattr
SKS Chromoplastics and a bag of P-Clips to attach to stays/forks and bridges.
If the fork crown isn't drilled you may need to get inventive with the metal work, or just use a couple of Zip ties.
Irish
by Irish
Crudcatchers 2's
Beancouter
by Beancouter
Many thanks; think the crudcatchers will be too narrow as only 23mm (I am on 28mm).
Will have a look at the clip option
