It is currently Sat Jan 20, 2018 2:32 pm
Post new topic  Reply to topic  [ 12 posts ]
PostPosted: Wed Oct 16, 2013 8:52 pm
I had to have my rear wheel rebuilt, so I will have to start over on that wheel. The tire has some glue on it. Would you try to remove the old glue before re-glueing?
My front wheel is sitting next to the bike, it looks like the glue has started to crack near the edges of the rim. I suppose I should remove the tire and re-glue it. Then same question as above: Should I remove glue from the rim and tire before re-glueing?
The tires in question are Challenge Limus. On an old wheelset I had a pair of Tufo Cubus, which I ran for two season without re-glueing (without problems).
Cannondale F-Si Team 2015
Cannondale F29 Team 2014
Cannondale F29 Carbon 1 2013
PostPosted: Wed Oct 16, 2013 11:28 pm
I always re-glue my CX tub's every season. Just for safety's sake. Glue cracking off the rim isn't a real indicator off worn glue tho. A good check routine I do... 1)deflate them to hold good shape 2) try to roll them off a bit by grab a bunch and rolling your wrist.. If you can pull them off the rim... Time to re-glue. I do this even after new glue jobs have finished to check how well I did.
PostPosted: Thu Oct 17, 2013 6:31 am
Thanks. And what about removing old glue?
PostPosted: Thu Oct 17, 2013 7:15 am
Depends - unless the glue is old, flaky, dried, or contaminated with dirt, you don't necessarily need to remove it. Pick off big globs and go to town with regluing.
If the glue is bad on the rim, google "remove tubular glue" or something like it and pick your favorite. It'll involve some kind of solvent, and lots of time/elbow grease.
If the glue on the tire is bad, there's way less info about it. I had to search for just that recently, and came up with very few resources. The one article I found suggested that if you think you need to re-use tires, you have to weigh your options: either the glue is good, and you and glue over top of it and it's no problem. If the glue is bad, you have to assess how bad. Either it's workable for a re-glue job, or you need a plan B. Apparently removal of glue is bad for the tire. So, you can either toss the tire, or send it off to tire-alert (Google it) and have them remove the old basetape and install anew.
In short, if you need to re-use a tire, it's probably good to just reglue it as is. Otherwise, it's likely to wear out before the glue on the tire itself goes bad.
Sent from my iPhone using Tapatalk - now Free
PostPosted: Thu Oct 17, 2013 7:37 am
Thanks for the tips. I'll try to remove the bigger, flaky chunks of glue.
PostPosted: Thu Oct 17, 2013 8:45 pm
Also be careful on the base tape. A tiny bit of it peeling off can be "glued" back on with out a problem. But if it's a big section you may have to find someone that can put in a new one for you. I have a batch waiting to send to some guy down in FL. Don't mix glue FYI and I always recommend mastik. Good testing and some tips on this site on why to use Vittoria mastik.
http://engr.ku.edu/~kuktl/
PostPosted: Thu Oct 17, 2013 8:53 pm
I have always used Vittoria's Mastik One. I don't think any of the base tape have peeled off :)
PostPosted: Wed Oct 23, 2013 8:47 pm
I reglue every couple of years, but that's between three wheelsets that I use between 'Cross and Road
If you have "goo-gone" where you are, that will help get the gunk off. If you don't have that, Citrus Degreasers work well too.
PostPosted: Wed Oct 23, 2013 9:04 pm
I tried to scrape off as much of the old glue as I could. I have just mounted the tires, so we'll see how it goes. Tubular tires are great, until you have to glue them. Then they become a pain in the a**. This was my core exercise for the day :)
PostPosted: Thu Oct 24, 2013 10:42 pm
Assuming the old glue isn't horribly dirty, a heat gun combined with scraping down to a clean, uniform surface is generally fine before you prep for more glue and a new tire. If you start with solvents like Goo Gone, Goof Off, or acetone, then all bets are off as for the integrity of the old glue, and you probably have to remove everything. Removing everything to get down to a bare rim is very time consuming.
PostPosted: Fri Oct 25, 2013 6:15 am
Thanks for the advice. Luckily I didn't use any of that :)
PostPosted: Sat Oct 26, 2013 2:26 pm
Whoa. Getting the best glue job on 'cross wheels is a very specialized process. The principal difference is the use of 'Belgian Tape' to 'fill-in' the rim profile vs the tire basetape profile (which also serves to provide some structure for the glue itself). If you need to remove the 'Belgian Tape', you need to get it all.
Once the glue cures well, use a layer of AquaSeal (or other uerathane-based sealant) to seal the gap between the tire basetape and the rim. That will help keep moisture and contaminants from affecting your glue job. That will protect your tire sidewalls, as well.
There are no new unread posts for this topic. 3M 08001 Glue
in Everything wheels
rgamble
Wed Apr 12, 2017 1:53 pm
rgamble View the latest post
There are no new unread posts for this topic. Arione 00 - which glue to hold covering down?
ParisCarbon
Sat Aug 05, 2017 2:55 pm
billspreston View the latest post
There are no new unread posts for this topic. How to remove Reynolds 58 wheel decals
Lafolie
Mon Jun 26, 2017 9:27 pm
Lafolie View the latest post
There are no new unread posts for this topic. Attachment(s) How to remove second bolt on Sram (Red) Chaingrings
jbattermann
Tue Aug 01, 2017 10:43 pm
jbattermann View the latest post
There are no new unread posts for this topic. Carbon Fibre repair glue to patch a seatpost?
Shrike
15
1774
Mon May 08, 2017 9:14 pm
thumper88 View the latest post
Users browsing this forum: No registered users and 2 guests
cron
