Trek Crockett Build
skiandbikecmh
by skiandbikecmh
Starting this thread to ask for advice and so you can follow me as I build up 2 new trek Crockett Framesets.
The frames should be in next week.
Here is the plan for the build:
Things I have or have ordered:
Trek Crockett Frame and fork
Bontrager xxx seatpost and alu stem. Ritchey Carbon Logic Bars.
Shorty Ultimate Brakes
Bontrager RXXXL Saddle
Farsports Carbon Wheels
Rival Shifters
Red Crankset
40t Wolf Tooth Ring
Stuff I don't have:
Sram XO Derailleur Short Cage
11-32 Cassette
Questions:
Should I get Type 2 for the derailleur, or not?
What tires?
What cassette for price/weight ratio?
My Bike:
viewtopic.php?f=10&t=110318" onclick="window.open(this.href);return false;
Ragamuffin
by Ragamuffin
A few questions first:
- Do you have a particular budget in mind?
- Clinchers or tubulars?
- Can an X0 shortcage fit a 32? I know some people have tried but I'm unsure of any definitive results. Why not just get a medium cage (aside from some added weight)?
People on my team are running the 40t Wolf Tooth ring with road Sram or a Type 2, in either case they seem to be happy with the performance so I'm not sure how big a difference it actually makes.
jooo
by jooo
@Ragamuffin - The cage length only dictates the total capacity. All of the SRAM MTB RD's will fit a 36 tooth cog.
skiandbikecmh
by skiandbikecmh
No specific total budget, using a lot of parts that I already have.
Definitely running tubulars. I have farsports 20mm tubular carbon wheels (1030 grams) and some old mavic tubular rims laced to ultegra hubs with 32 holes. I ran grifos last year for the whole season, but the tread was peeling off by the end. Looking at Clement, Vittoria, Maybe FMB.
The xo clears a 36 regardless of cage length. that is why I am running it, for the cassette clearance, and higher spring tension for shifting in muddy conditions.
My Bike:
MARLON
by MARLON
Seen this
I know its disc but maybe some Inspiration
http://www.cyclingdirt.org/article/2256 ... k-Crockett
BACK IN BLACK
skiandbikecmh
by skiandbikecmh
Yes, katie's bike is definitely a good place to draw some inspiration. I would be more interested to see her canti bikes, since that is what I will be running. I don't have quite as large a budget, or as many sponsor obligations. I will be running mostly the same cockpit, and pedals, but my drivetrain will be a bit more unorthodox. I am thinking though that the frame should be very nice, if it is good enough for Katie, then it is good for me. The friction tape on her shifter also seems like a good idea. Sram shifters do get slippery when wet.
My Bike:
grover
by grover
Go type 2 rear derailleur. The 'cross season has just finished in Australia. I had a single ring setup with wide/narrow chainring (made by Fetha components in Melbourne) on both bikes. I predominantly rode the bike with an X.0 short cage type 2. Zero chain drops. I did have a couple of chain drops on the bike with a standard derailleur.
skiandbikecmh
by skiandbikecmh
Thank you for the input, can I ask you what the conditions that you dropped the chain in? Just curious to know what the weak point is.
I definitely don't want any chain drops, so I will go with the Type 2.
My Bike:
skiandbikecmh
by skiandbikecmh
I will be posting pics as the parts come in and it starts coming together. Rings came in today. I called the shop and the frames should be in this week or next week.
My Bike:
Peter_E
by Peter_E
Keep in mind you need a barrel adjuster or in line adjuster when combining mtb derailleur and double road shifter. I realised that after I put the stuff on my bike.
Skickat från min MT15i via Tapatalk 2
skiandbikecmh
by skiandbikecmh
So trek informed me that the frames wont be in until January 20th at the earliest. I cancelled the order given that the season will be well over for me by then. Thinking that I will be able to wait until Sven Nys' new bike (assuming trek makes him something carbon) comes out with disc. Also CX1. Many things to be excited about within cross tech for next season.
