It is currently Thu Apr 27, 2017 2:56 am
PostPosted: Mon Sep 30, 2013 12:54 pm
Hi WW!
I've got a nice wheelset based on classic King hubs. Since Chris King does not offers 11speeds freehub upgrade for this particular hub, I was wondering if it was possible (to the best of your knowledge) to transform a 11 speeds cassette into a 10 speed cassette by removing one cog and adding a proper width spacer.
If I use 11 speeds shifters (ultegra 6800) and I adjust the limits screws of my 11 speeds rear mech, I should be fine, right?
I made a little graph to compare the widths 11 speeds, 10 speeds and 11 minus 1 speeds cassettes
11 speeds cassette minus one cog on 10 speeds freehub
inb4: transforming 11 speeds to 10 speed is stoopid. I've got my reasons.
Thanks for your inputs!
PostPosted: Mon Sep 30, 2013 2:02 pm
Math looks fine to me, so I don't see why not.
For safety I'd be having a spare last click to the small sprocket, rather than the other end of the cassette.
There's sometimes a buggy.
One.
PostPosted: Mon Sep 30, 2013 2:08 pm
Yeah I could also add two small spacers at each end. The 2,54mm spacer is a regular 9speeds cassette spacer.
PostPosted: Mon Sep 30, 2013 2:13 pm
You can do that, but if you are using a Shim Cassette the 2nd to the last cog doesn't have the groves for the lockring to get a good bite on.
I ran my 7900 cassette with the new DA until I bought a new set of wheels and it worked just as well with 10 cogs as it did with 11.
PostPosted: Mon Sep 30, 2013 2:52 pm
I would probably remove a middle cog; 16t probably.
PostPosted: Mon Sep 30, 2013 6:39 pm
Works fine. I did this with a PG-1170 cassette, and removed the 16T cog, and moved the spacer from the 16T cog to the inside of the cassette. The 15-17 shift isn't as smooth as it could be, but it works pretty well. FWIW, I'm using red 22 shifters - spacing for shimano should be the same though.
I plan on picking up another wheelset soon, but this is a reasonable bridge until then.
PostPosted: Tue Oct 01, 2013 12:45 am
Thanks!!!
PostPosted: Tue Oct 01, 2013 4:59 am
-Ah ok, I see what you are saying.
There are no new unread posts for this topic. Weight minus accessories?
in Everything wheels
phourgenres
Mon May 09, 2016 1:50 pm
phourgenres View the latest post
There are no new unread posts for this topic. Zonda freehub outer bearing - replace or new freehub body?
island
Fri May 06, 2016 11:38 am
island View the latest post
There are no new unread posts for this topic. Campagnolo Freehub help
marco fan
Thu Apr 20, 2017 2:13 pm
Madone69 View the latest post
There are no new unread posts for this topic. Tune freehub
steelme
7
338
Wed Apr 12, 2017 9:51 pm
steelme View the latest post
There are no new unread posts for this topic. a freehub question
paregreen23
Wed Oct 19, 2016 9:59 pm
paregreen23 View the latest post
Users browsing this forum: No registered users and 1 guest
