It is currently Tue Jan 23, 2018 12:55 pm
Post new topic  Reply to topic  [ 4 posts ]
PostPosted: Sat Sep 28, 2013 4:56 pm
I've just got these brakes on my CX bike. The rear feels amazing, great bite etc. no dragging. The front on the other hand feels great but is dragging a sh!t load. I've centred the calliper, removed the pads and tried to reset the pistons and played with the bolts on the actuator arm to no avail. There looks to be a bleed screw, I think the reservoir may be overfilled but I'm not sure. I mostly work in road bikes so don't know too much about hydraulic systems. The levers I'm using are Ultegra 11 if that makes any difference, using stock TRP disks.
I have also emailed TRP asking for help but I need to get it all working as I have training and races this weekend and coming week. I would ask my local shop but that's me and these are the first HY/RD brakes we have had.
--Max.
PostPosted: Sun Sep 29, 2013 1:29 pm
Guarantee?
Yes, there is a bleeding screw.
push pistos-pads with a tirelever back
if thats not possible, there is to much "oil" inside
let a few drops out
CX RACE 12.12.15 http://www.cx-sport.de/content/cyclocro ... cup-cochem
PostPosted: Tue Oct 01, 2013 5:08 am
Elmar is right, you could try this..
pump the brake a few times, then open the bleed screw on the brake a 1/2 turn or so while lightly pulling the lever 'til you see a drop of fluid, then close the screw while holding the lever in that position. You can then do the same with the lever...
I haven't worked on the new Shimano hydro road levers, but bleeding Shimano usually lets you push fluid from the caliper up into a reservoir connected to the lever..
PostPosted: Tue Oct 01, 2013 8:25 am
We sold a lot HY/RD and all of them work well!
How about guarantee?
There are no new unread posts for this topic. Etap problems
Jase46
10
2199
Wed Feb 01, 2017 4:23 am
moonoi View the latest post
There are no new unread posts for this topic. Campy drive train problems
DeLuz
13
1144
Mon May 22, 2017 7:13 pm
2lo8 View the latest post
There are no new unread posts for this topic. Roval 64 CLX Tubeless Problems Leaks
in Everything wheels
GatSCU
10
937
Thu Sep 07, 2017 2:16 pm
Geoff View the latest post
There are no new unread posts for this topic. Carrera Bikes - Any opinion, problems?
TheBlackPath
15
1569
Wed Nov 15, 2017 4:39 pm
TheBlackPath View the latest post
Users browsing this forum: nickl and 2 guests
