It is currently Sun Feb 26, 2017 1:42 pm
Post new topic  Reply to topic  [ 21 posts ]  Go to page 1 2 Next
 Post subject: C24's for cyclocross
PostPosted: Fri Sep 06, 2013 2:56 pm
Hey guys, never really gotten a straight answer here on this question.
Would you guys consider a set of 7850 c24's strong enough for a race wheel-set for cross?
:beerchug:
Thanks for the info.
 Post subject: Re: C24's for cyclocross
PostPosted: Sat Sep 07, 2013 12:20 am
I would. Shimano pride themselves on durability, and if their carbon wheels are good enough for so many world champs, I'd say the alloys are fine too.
PostPosted: Sun Sep 08, 2013 4:31 pm
The aluminum clincher? I wouldn't be worried about strength, but that thin braking surface won't last long.
PostPosted: Sun Sep 08, 2013 5:40 pm
A buddy of mine swears by them, stiff and supremely robust according to him.
PostPosted: Mon Sep 16, 2013 4:22 pm
My C24's held up well until the last jump.. needed major truing.
Parlee Z3c
Independent Fabrication SSR // 953
Independent Fabrication Planet X
Knolly Chilcotin
PostPosted: Mon Sep 16, 2013 11:09 pm
I've raced a whole season on RS80s with no issue, I'm 85kgs and not very easy on my equipment.
PostPosted: Fri Apr 25, 2014 10:40 pm
I have only seen shattered c35's due braking too hard. Alloy wheels are hard to break so should really be a problem.
You could also consider dura-ace hubs with mavic open pro rims. Should be around the same price but a bit more solid.
PostPosted: Sat Apr 26, 2014 10:34 am
There are 2 versions of the c24.
The tu version (full carbon and for tubes) is good for cross. The clincher also but the backing surface won't last long.
PostPosted: Sat Apr 26, 2014 11:37 am
Actually there are 3 versions. Tubular (tu), tubeless (tl) and normal clincher (cl)
PostPosted: Sun May 11, 2014 9:09 am
silly question.. but what's the widest tire you can run on the c24 alu?
PostPosted: Sun May 11, 2014 1:56 pm
They are a fairly standard sized Road rim, so you'll be fine up to 33mm (Max size for cx).
PostPosted: Sun May 11, 2014 3:38 pm
Nice... too bad I have the DA 7800 wheelset... Max is only 28 for this one. :(
Sent from my SGH-M919 using Tapatalk
PostPosted: Sun May 11, 2014 4:51 pm
No it's not.
That's just what shimano tell you.
Almost the entire field of any cx race will be running tyres wider than that on rims that size, or narrower.
Only issue is if you are trying to run wide tyres at road pressures.
I've done ~10 seasons on open pro. With their 16(?) mm internal width and tyres up to 38mm. No issues.
Keep the pressures sensible, 40 psi or less, and you'll be just fine.
PostPosted: Sun May 11, 2014 4:53 pm
You could probably even go tubeless without breaking sweat.
PostPosted: Sun May 11, 2014 5:46 pm
mattr.. sure about that? if it is.. then i can return the 28c tires - Continental Tour Ride Urban Bicycle Tire (700x28) i just picked up.
There are no new unread posts for this topic. Cyclocross - Light vs Tough? Or can you have both?
mcbbcn
10
677
Thu Feb 02, 2017 11:21 pm
stormur View the latest post
There are no new unread posts for this topic. Cyclocross is tough on the parts !!
LouisN
13
915
Tue Nov 15, 2016 4:18 pm
jcrr View the latest post
There are no new unread posts for this topic. Orbea Cyclocross Bike, 54 cm
pritchet74
Sun Jan 22, 2017 6:28 pm
pritchet74 View the latest post
There are no new unread posts for this topic. Any issues with Challenge cyclocross tires?
jdecraene85
11
851
Wed Apr 06, 2016 6:46 am
mattr View the latest post
There are no new unread posts for this topic. McGovern Cycles custom cyclocross bike
gfeldy
Mon Sep 26, 2016 3:21 pm
LouisN View the latest post
Users browsing this forum: No registered users and 2 guests
