so what are the lightest cx disc bikes ? (specs and pics)
http://www.edgesportsuk.com/store/index ... cross.html
^^ this one was the other one.
Any reviews from users of these brakes? I'm interested in shedding some weight by replacing my spyres and I'm also interested in trying out the improved feel of a hydraulic.
kingkongsfinger wrote:Link to the frame, i also bought the seatpost, seatclamp, two headsets and two rear hangars. http://flyxii.com/en/products/flx-fr-602.html
Did you have to drill out the cable stops in order to run the hydraulic lines through the frame? What about the bottom bracket guide?
ITTY wrote:kingkongsfinger wrote:Link to the frame, i also bought the seatpost, seatclamp, two headsets and two rear hangars. http://flyxii.com/en/products/flx-fr-602.html
No drilling required and the frame has a nice access point under the BB which guides the cables, this can be removed with a small allen bolt.
"I could have done this job myself in five minutes, but as things turned out I had to spend two days trying to find out why it had taken someone else three weeks to do it wrong."
- Shop Owner
We are testing this brake since three months.
Untill now they are excellent.
But we didnt check them at low temperatures.
Next weekend we will put several sets in the fridge and ride them after
CX RACE 12.12.15 http://www.cx-sport.de/content/cyclocro ... cup-cochem
I finally got my Felt frame, the F5X was lost by the carrier, so I was able to get a F4X as a replacement.
As mentioned, it's Ultegra Di2 plus TRP HY RD brakes, just finished the build to race tomorrow, weighs in at 8.25kg without bar tape - was not my objective to be particularly light. But I'm well pleased with it.
Will post some pics, prior to getting it dirty
- Shop Owner
ckyle wrote:For anyone using TRP Spyres or I guess the Hy/Rd too, have you found a pad/rotor combo that works better than what comes with the brakes?
Swisstop organic.
Its more important to use special cablesets like TRP Disc Connect or similar ones.
mentok wrote:I recall seeing an alternative version of the TRP Hy/Rd recently but i didn't bookmark the link. They were lighter, cheaper and I believe that the reviews said they didn't have some of the set up complications that the Hy/Rd suffers from.
Any ideas?
are you referring to the Juin Tech R1's?
as for light CX bikes... my TCX comes in at a portly ~7.5kg
elmar schrauth wrote:ckyle wrote:For anyone using TRP Spyres or I guess the Hy/Rd too, have you found a pad/rotor combo that works better than what comes with the brakes?
Swisstop organic.
http://www.trpbrakes.com/category.php?p ... 8&subcat=0
I looked at that and it looks like it's just compressionless housing. I wonder how that is different from other housing that is supposed to be compressionless?
In the TRP Spyre Mud post, people mention adding a barrel adjuster to the cables so you can compensate for excessive pad wear. That seems like a good idea.
2013 Fuji Altamira CX 1.1 frameset
Shimano 6800 complete group
TRP HyRd 160mm front/rear
Yokozuna Reaction cables
FarSport 25x38 tubulars
Clement LAS tubulars
FSA bar/stem/seatpost
Garmin Ant+ sensor and crank+wheel magnets, bar mount.
Weight without pedals, bottle cages.
8.07 kg
17lb 13oz
sorry for the busy background...
8.07 kg
17lb 13oz
- rasmussloth
Where do you live?
It must be a place without mud since you glued on some Clement LAS...?
The saddle may be heavy but is comfortable though. Is not the area where I'm willing to sacrifice comfort for weight. And those are not the only wheel set that goes on that bike.
