Belt drive, disc brake compatible, 700c frameset. =AWOL/pics
xnavalav8r
by xnavalav8r
Anyone know of a 700c frameset that is both disc brake and belt-drive compatible? Ideally with rack and fender mounts. Also clearance for 32-25c rubber.
Any suggestions? I don't have the budget to go custom on this one.
thisisatest
by thisisatest
Like the Specialized Source 11?
Sent from my EVO using Tapatalk 4 Beta
xnavalav8r
by xnavalav8r
Nice, but not what I had in mind. After doing some digging, I found the Spot Mod Disc SS. This might work.
http://spotbrand.com/bikes/product-page/?shopp_pid=32
-Robin-
by -Robin-
BMC UrbanChallenge, but unsure whether you can buy the frameset only
xnavalav8r
by xnavalav8r
My favorite custom builder apparently had the same idea...
-Robin-
by -Robin-
Any idea about the brand/type of fenders on that thing ?
CarlosFerreiro
by CarlosFerreiro
Shand Stoater Plus?
http://www.shandcycles.com/frames/allro ... -overview/" onclick="window.open(this.href);return false;
jcmkk3
by jcmkk3
Most of the Tout Terrain frames can take a belt drive. Some even have integrated racks if you plan to always have one attached.
Van Dessel also makes the Whiskey Tango Foxtrot that can be setup as pretty much anything.
xnavalav8r
by xnavalav8r
I am having no luck with this project so far. The only framesets I've found that I can afford are not compatible with the Alfine di2. I may abandon this idea and stick to a conventional, chain driven commuter this winter.
xnavalav8r
by xnavalav8r
I think I found the answer... Co-Motion Cascadia Alfine di2.
trychle
by trychle
Hi Ted,
Have you already looked into the *wait for it* Specialized AWOL?
It can take a belt drive, has fender mounts and is compatible with disc brakes and Alfine di2..
There is an entire blog dedicated to this bike and the rides that are completed on it. (http://wearegoingawol.tumblr.com/)
The only downside is that you will have to buy an entire bike and strip it completely.
I hope this was useful. Ciao.
xnavalav8r
by xnavalav8r
Thanks. Yes. I actually emailed Specialized about the bike to ask if it was compatible with the belt/di2 Alfine and they never replied. For a number of reasons, including non-existent customer service, I will most likely stay away from Specialized.
Ultimately my wallet will make the final decision.
jooo
by jooo
What's the specific issue with di2 compatibility on some of the frames?
If you found something that met your needs other than the belt drive, would you consider having a splitter retrofitted? It shouldn't be a costly or particularly difficult mod on most frames.
xnavalav8r
by xnavalav8r
The di2 motor for alfine takes up a lot of space between the dropout and the hub. Many frames don't have enough room for a belt when using the electronic alfine system.
xnavalav8r
by xnavalav8r
Co-Motion and Gates revealed this bike on their respective Facebook pages. I sent Co-Motion an inquiry regarding availability and purchase price. They responded right away. So, seriously considering this bike.
