Post new topic Reply to topic  [ 7 posts ]
 Post subject: Cross brake set up?
PostPosted: Tue Dec 20, 2005 3:46 pm
Hi. im new to this cross lark...!
how the hell do you set up cross levers, just bought some, and have not go a clue!
pics would be good!
Ta. :roll:
 Post subject: this should help
PostPosted: Tue Dec 20, 2005 3:48 pm
http://www.cyclocrossworld.com/Tech.cfm ... Disabled=0
 Post subject:
PostPosted: Tue Dec 20, 2005 4:35 pm
Ta!
But still could do with a pic, cos not sure !
I told you i was new.!
Sorry.
 Post subject: pics
PostPosted: Tue Dec 20, 2005 4:52 pm
http://images.google.com/images?sourcei ... a=N&tab=wi
 Post subject:
PostPosted: Tue Dec 20, 2005 5:05 pm
AAaaah! :shock:
I need to know what happens to the cables!!!!!!!!!!
Where they should go!!
Sorry.
:wink:
 Post subject:
PostPosted: Tue Dec 20, 2005 5:41 pm
The outer casing runs from the original lever (ergo/sti etc) to the back of the new CX lever (the side without the barrel adjuster). Then another piece of outer continues from the CX lever (barrel adjuster side) down to you caliper.
The inner runs from your original lever through the first outer between the two levers, then through the CX lever, out the other side and into the secound piece of outer and down to your caliper in the normal way.
All the new lever does is interupt the outer casing, the inner just goes through as normal.
The way it works is by efectively making the outer casing longer by opening the gap between the two pieces on each side of the lever. Which has the same effect as pulling the inner cable the way a normal lever works.
Hope this helps.
 Post subject:
PostPosted: Tue Dec 20, 2005 9:02 pm
Mega.!
Got it... thanks.
I have now done it. ta again.
You sure explain stuff good.
Ta!
Users browsing this forum: Exabot [Bot] and 2 guests
There are no new unread posts for this topic. Replacement for brake nut on rear brake bridge
Y26
Thu May 30, 2013 3:52 am
lechat View the latest post
There are no new unread posts for this topic. XX1 for cross?
in Cyclocross / Touring
limba
Tue Dec 25, 2012 11:55 am
grover View the latest post
There are no new unread posts for this topic. Campag In Cross
dereksmalls
7
657
Thu Feb 28, 2013 5:38 am
dvincere View the latest post
There are no new unread posts for this topic. FSM CROSS 2012
FSM
Thu May 09, 2013 7:50 am
bournepeter View the latest post
There are no new unread posts for this topic. XT Cranks for Cross
owen
Mon Dec 10, 2012 4:16 am
cron
It is currently Thu Jun 20, 2013 12:35 am
