It is currently Sat Mar 25, 2017 1:14 am
Post new topic  Reply to topic  [ 97 posts ]  Go to page 1 2 3 4 57 Next
PostPosted: Mon Dec 19, 2005 12:34 pm
I will post pictures and soon as I get my hands on this frame! I also got a Phyton fullcarbon fork but no headset? I thought that this would come with the frame - anyone knows what kind of integrated fittings the frame uses?
Thank!!!! :D
My blog
 Post subject:
PostPosted: Mon Dec 19, 2005 1:27 pm
Mads, your frame should come with an FSA headset! They come in a small package with the frame including the headset cups you have to push into the frame.
Congratulations with the frame btw, what colours did you end up getting?
 Post subject:
 Post subject:
PostPosted: Mon Dec 19, 2005 1:30 pm
Are you sure? It was my friend who searched the package and he did it rather quickly - I will look when I pick out the package in the afternoon!
I got the White/Black/Silver - look really nice compared to the black and blue versions!
My blog
 Post subject:
PostPosted: Mon Dec 19, 2005 1:41 pm
Yes, I'm positive you get this with the frame (and need it) unless you somehow ordered a version with standard headset? Have a good look in the box, there should be a little plastic bag with the headset in there somewhere. When the box comes straight from Ridley they usually put these inside the small boxes that prevent the frame from moving inside the box.
 Post subject:
PostPosted: Mon Dec 19, 2005 1:44 pm
I have just send him an sms and now he has replied that it was there - thanks for information so I could make him look again :-)
My blog
 Post subject:
PostPosted: Mon Dec 19, 2005 1:46 pm
That's good news! Now go and pick it up and let us see some pictures :wink:
 Post subject:
PostPosted: Mon Dec 19, 2005 5:41 pm
give us the solo weight of frame fork and headset
thank you
elmar :lol: 8)
 Post subject:
PostPosted: Mon Dec 19, 2005 9:00 pm
Here are the information you asked for:
Ridley Crosswind (size 48cm) with geardrop = 1455 grams
4ZA Phyton (uncut) = 395 grams
FSA integrated headset (without expander plug and bolt) = 100 grams
Wheel for front derailleur and steel bolt (for road der) = 9 grams
Ridley seatclamp = 25 grams
FSA SLK Compact MegaExo crankset with integrated BB = 820 grams (included 28 grams for alu tube -> real weight is 792 grams)
Here is a picture of the frame - looks really nice!!!
Buildlist:
FSA OS-115 stem with ti-bolts,
Ritchey WCS OS handlebars
Extralite The Post UL seatpost,
Seat?
Shimano Ultegra gears
4ZA Froglegs brakes,
Mavic Ksyrium Elite wheels,
Continental Twister tires.
I will post more pictures as they come!
My blog
 Post subject:
PostPosted: Tue Dec 20, 2005 12:17 am
sweeeeeeeet! Say, does the Python fork really weigh a mere 400 g!??!? That's unbelieveable :shock: my fork weighs 570 g. Need to get my hands on a python. that's even lighter than the Kuota and Easton forx, right?
Could you do me a favor and measure the crown race width (?)? I wonder whether the diameter of the fork's crown where it meets the frame is too wide to fit a conventional headset
 Post subject:
PostPosted: Tue Dec 20, 2005 1:12 am
Do you mean it's possible to remove the alu tube between the bearings? On your picture a orange one.
 Post subject:
PostPosted: Tue Dec 20, 2005 7:01 am
There was a tube inside the bottom bracket - I think it was only there so the BB wouldn't be damaged before mounted!
XTC-Max wrote:
Could you do me a favor and measure the crown race width (?)? I wonder whether the diameter of the fork's crown where it meets the frame is too wide to fit a conventional headset.
I will take some pictures tonight - the fork is for integrated headset and it looks quite wide at the bottom but I will take pictures for you tonight!
My blog
 Post subject:
PostPosted: Tue Dec 20, 2005 10:35 am
I think it has been discussed on the road forum before, so if you want more opinions you can do a search there.
The outer tube is to make the bb watertight, so if the bb area in your frame is closed (like on some cf frames) and you are shure no water can come in there, you could leave it out. I wouldn't recommend it on a cx bike though!
There is another tube inside the bb on the more expensive version of the FSA bb. It is to make sure you don't crush the bearings when installing the cranks. When carefully installed the cranks have worked fine withouth this sleeve for me. Again, I won't recommend you removing it, but I haven't had any problems doing so. If you overtighten your right crankarm you could put extra force on the bearings that will destroy them over time, that's why the extra sleeve is there.
Here are a couple of pictures of a bb you get (ao) with the K-Force road cranks. (It's ITA threaded so slightly heavier)
 Post subject:
PostPosted: Tue Dec 20, 2005 10:39 am
Yes - it's the tube in the middle picture!!
It also worked fine for me without using the innertube then I mounted the bearings - I thought it was only to not damage the BB but you recommend using it? It's a massive 28 grams so I might leave it out :-)
My blog
 Post subject:
PostPosted: Tue Dec 20, 2005 12:33 pm
Mads, I'm not using the 28 gram piece in my road bike, only the 16 gram outer shell. No problems in the 4-5 months I used this setup this year, just be carefull not to overtighten the crankarm when mounting it. BTW, the cheaper versions of the FSA cranks don't have this part at all. Guess it has something to do with the design of the crankarms?
I wouldn't really recommend you to leave the sleeve out, only saying that it didn't result in any problems for me (yet).
If you are worried about the extra forces on a cx bike you could always drill the part a bit to make it lighter.
 Post subject:
PostPosted: Tue Dec 20, 2005 12:47 pm
okay - just seems strange because shimano has the same design and they don't use this innertube in their box!
My blog
 Post subject:
There are no new unread posts for this topic. Attachment(s) frame choice to move of on Ridley Helium
eajohnson
23
2677
Sat Dec 10, 2016 11:05 am
alastairb View the latest post
There are no new unread posts for this topic. Attachment(s) Hi new to WW today
ViggenNut
10
1336
Mon Mar 06, 2017 10:39 pm
Stormtrooper View the latest post
Frankie - B
34
1981
Fri Feb 24, 2017 12:30 am
nobuseri View the latest post
There are no new unread posts for this topic. Attachment(s) Today in things that suck
[ Go to page: 1 2 3 4 5 ]
kfreytag
63
4330
Sat Dec 31, 2016 12:48 am
kfreytag View the latest post
Users browsing this forum: Baidu [Spider], Yahoo [Bot] and 2 guests
