Post new topic Reply to topic  [ 5 posts ]
PostPosted: Thu Dec 15, 2005 3:45 am
Does anyone make a cross frame with a 50.5 or less top tube?
How about 650c or 26" (mtb) cross tires?
 Post subject:
PostPosted: Thu Dec 15, 2005 3:59 am
Is it for a small woman or a child? Either way, kona makes a 24" wheeled CX bike i believe.
 Post subject:
PostPosted: Thu Dec 15, 2005 4:16 am
Yes... Kona and Redline both make 24" cross bikes... I'm looking for something a little larger because I've found that 4'6" is about max for those frames...
 Post subject:
PostPosted: Thu Dec 15, 2005 4:45 am
It's likely only a custom frame/fork will work for 26 inch tires. Independent Fabrication has made cross frames with 26 inch wheels before and they work very well. I built up the first models they ever made that way and they rode really well- no toe overlap on a rider with a size 41 shoe and 170mm cranks. The stock44cm frame has a 50cm top tube, and with 26 inch wheels they might be able to go shorter.
Shwalbe makes a 26 inch tire that can be used for cross- it has a pretty good tread and is under the UCI 35mm. Hutchinson also makes a tire that fits a 26inch rim. And Dugast can make 650's if cost is no object......
 Post subject:
PostPosted: Thu Dec 15, 2005 6:37 am
surly makes the crosscheck with 650s or at least they used to.
Users browsing this forum: No registered users and 2 guests
There are no new unread posts for this topic. Frames for a small girl
welkman
11
686
Sat Aug 04, 2012 6:07 pm
bikedoc View the latest post
There are no new unread posts for this topic. cyclo-cross tires
in MTB
backflat
Fri Aug 24, 2012 11:07 pm
backflat View the latest post
There are no new unread posts for this topic. SRAM Red RD and small cog help
styrrell
Tue Mar 26, 2013 3:37 pm
indigo View the latest post
There are no new unread posts for this topic. Attachment(s) Let's see your small bikes...
CarpetFibre
33
4781
Sun Dec 16, 2012 2:33 am
pocketbeagle View the latest post
It is currently Sun May 19, 2013 12:19 pm
