Post new topic Reply to topic  [ 3 posts ]
PostPosted: Wed Feb 13, 2013 3:17 am
I just bought a cyclocross frame :D...
Now I need to shop for a fork. But I have no idea of what to look for.
I saw some numbers that don't tell me anything, from 47 to 50 offset..., etc... :noidea:
I'll use the bike mostly as a second bike, commuter, for spring and fall use but mostly on tarmac, and gravel roads.
I'm not planning on doing any real cyclocross racing.
So what should I look for in terms of offset and rake ? What does it change in handling, etc...?
Thanks for the answers,
Louis :)
http://www.ccsalma.com
PostPosted: Wed Feb 13, 2013 11:19 pm
The combination of head angle and fork rake comprise "Trail". Trail is basically what makes your bike steer the way it does.
http://en.wikipedia.org/wiki/Bicycle_an ... e_geometry
Steeper head angle and more rake equal faster steering, shallower head angle and less rake equal more stable steering.
Find an online trail calculator, plug in your head angle and the rake(s) of the available forks, and see what works well. You'll probably want something with more trail (i.e. - more stability) for commuting. So aim for something like 6cm of trail. I think anything under about 5.2cm is nearly unrideable at high speeds, 5.5 - 5.6 is a nice sweet spot for road racing, something a bit more stable like 5.7- 5.8 for 'cross racing.
Cyclocross bikes typically have 72 - 72.5' head angles, which result in fairly stable steering when paired with a 43-45mm raked fork. Steeper head angles (73') would typically require a 43mm fork, while really shallow head angles (below 72') can get away with 47-50mm forks, but you get some "wheel flop" at low speeds. That latter combination is typically used on smaller frame sizes to reduce toe overlap, but it's not necessarily ideal for handling.
PostPosted: Thu Feb 14, 2013 1:12 am
Thanks JBV,
Everything I wanted to know is in your post :beerchug: .
Lots of 47-50mm forks available at a good price, but with my 56X54cm frame, I'm pretty positive I wouldn't be a good match now.
Louis :)
Users browsing this forum: No registered users and 2 guests
There are no new unread posts for this topic. Attachment(s) Front fork rake?
Sirius
11
787
Wed Jul 11, 2012 4:58 pm
Sirius View the latest post
There are no new unread posts for this topic. 2010 CERVELO RS 54 fork rake
digitalnorbs
Wed Apr 03, 2013 7:07 pm
digitalnorbs View the latest post
There are no new unread posts for this topic. "Open mold" asian cyclocross carbon fork
in Cyclocross / Touring
LouisN
7
806
Wed Apr 17, 2013 10:31 pm
LouisN View the latest post
There are no new unread posts for this topic. Looking for carbon 1 1/8" forks with 43 rake & 365 A to C
dieselgeezer
Thu Mar 14, 2013 11:59 pm
cyclenutnz View the latest post
There are no new unread posts for this topic. SRM zero offset value, off the scale.
coureur1
Wed Mar 06, 2013 3:45 am
Squint View the latest post
It is currently Sun May 19, 2013 2:40 am
