Post new topic Reply to topic  [ 9 posts ]
PostPosted: Mon Feb 11, 2013 8:02 pm
On a CX frame with top pull housing routing, what's the options when there is no existing "device" on the bottom of the seat tube to route the cable around and use a bottom pull FD ?
Louis :)
http://www.ccsalma.com
PostPosted: Mon Feb 11, 2013 8:26 pm
Are you looking for something like this: http://problemsolversbike.com/products/ ... ps_pulleys
Or do you want to re-route the cable?
PostPosted: Mon Feb 11, 2013 11:36 pm
Yes, that's what I was looking for :D. Thanks the_marsbar. That clamp looks heavy !!!
I was also looking at possibly the option of drilling the seat tube and installing the pulley directly.
Louis :)
PostPosted: Tue Feb 12, 2013 8:12 am
There's also the Speen adapter. There should be plenty threads in the MTB section, try a search.
There's even a thread in this section as well: viewtopic.php?f=10&t=94430&hilit=speen+adapter
PostPosted: Tue Feb 12, 2013 1:45 pm
Carbon-Ti make basically the same thing too.
PostPosted: Sun Feb 17, 2013 9:39 am
Shimano makes derailleur specially for cc and top pull. FD-CX70 is cheap and works great.
PostPosted: Sun Feb 17, 2013 9:53 am
Here is FD-CX70 picture of the weigth
PostPosted: Mon Feb 18, 2013 9:36 pm
Louis, I tried a few different things. I finally settled on the Speen and it has worked perfectly.
PostPosted: Sat Feb 23, 2013 3:44 am
I brought the frame to the local bike store.
The seat tube (aluminium) thickness was good enough to drill a hole and put an insert for a pulley. Problem solved.
Frameset is 1269 g with hanger BTW :D .
Louis :)
Users browsing this forum: Bing [Bot] and 2 guests
There are no new unread posts for this topic. Experience with C-4 straight pull front hub
Anders
Wed Jan 09, 2013 2:54 am
boneman View the latest post
There are no new unread posts for this topic. Is this the end of the front derailleur?
SWijland
23
2013
Sun Dec 23, 2012 2:05 pm
Franklin View the latest post
There are no new unread posts for this topic. Frm front derailleur
in MTB
Dennis
Sat Dec 22, 2012 7:40 pm
Dennis View the latest post
There are no new unread posts for this topic. BTP front derailleur
kevosinn
Wed Sep 19, 2012 2:14 am
kevosinn View the latest post
There are no new unread posts for this topic. Front derailleur problem
wally318
Mon Apr 15, 2013 4:59 pm
sigismond0 View the latest post
It is currently Fri May 24, 2013 4:36 am
