Post new topic Reply to topic  [ 14 posts ]
PostPosted: Wed Dec 19, 2012 2:41 am
Anyone got any experience with them? Also are there currently any companies doing CX size latex tubes? I've only found expensive Challenge ones on eBay.
PostPosted: Wed Dec 19, 2012 1:24 pm
I've run Challenge latex tubes with Grifo rear/Fango front for the last two seasons - 30 races on this combo in a variety of conditions. On wide (23 mm Revolution rims), a near tubular setup - able to race at 28 psi rear / 25 front without flats at 6'1" 170 lbs. This combo hooks up well in corners. Don't bother if you're not using good cotton sidewall tires or if you're not racing - the real advantage is in being able to run your tires 'squirmy' when conditions dictate - butyl sidewalls preclude this before you even get to tubes. I think the wide rims also contributed to my success with this setup. I'm not aware of other cross latex tubes, but the Challenge are very well made and worth every penny for my purposes.
PostPosted: Wed Dec 19, 2012 5:46 pm
Even though the tread is separate from the casing, where did you find clincher Challenge cross tires with cotton sidewalls as I thought the clinchers used reinforced polyester casings?
PostPosted: Thu Dec 20, 2012 2:26 am
You're right - the walls are reinforced polyester (and not cotton) on the 'open tubular' Challenge line. I was referring to latex tubes being useful with these, as opposed to the lower line all butyl (blackwall) tires.
PostPosted: Thu Dec 20, 2012 2:00 pm
We use the wide (28MM) Vittoria Latex Tubes, too.
They work well up to 37mm, more we didnt check.
www.crossladen.com
www.cx-sport.de
PostPosted: Thu Dec 20, 2012 2:36 pm
I have used normal Michelin A1 AirComp 22/23 latex tubes for years. They will stretch to CX size without problems...
Slammed. Campy. Tubulars.
PostPosted: Thu Dec 20, 2012 4:54 pm
I have used Michelin, Challenge and Vredestein tubes, all in road (20-25mm) size. I also have used a few Challenge 30-32mm ones. I use them on skinny 19mm rims, with 35mm tires, and I have run my tires as low as 28psi at my 62kilos.
Of the above, the ones I have pinch flatted are the Challenge 30-32mm ones. Go figure...
Also, I will come out and say I have not had the best of luck with Stans and latex tubes. One of these days I'm bored I may try the glitter idea, see if that helps...
"If it ain't broken, it could be lighter"
PostPosted: Thu Dec 20, 2012 10:45 pm
The glitter idea? Please enlighten me
PostPosted: Fri Dec 21, 2012 4:12 am
Glitter idea as explained here: http://www.cxmagazine.com/add-sparkle-t ... ason-flats
Like I said, one of these days I'm bored.... and after a few :beerchug:
PostPosted: Sat Dec 29, 2012 10:02 pm
A bit off topic but...
Has anyone tried the super wide clinchers such as Enve Smart with latex inner tube set up.
I currently run tubulars but life has become too busy for 3 days of proper gluing.
I am encouraged to hear people running 30psi on the 23mm wide rims. If this is true then the Smart system wheels could be even more pinch flat resistant.
Enve makes a full range of MTB rims so I am hoping that durability of the clincher rim would not be an issue.
Anyways...thoughts on this?
PostPosted: Tue Jan 29, 2013 8:24 am
it works
i took Latex Cx-Tubes for small 29er Tires
www.crossladen.com
www.cx-sport.de
PostPosted: Tue May 07, 2013 10:14 am
:smartass: The latex tubes in the bark ascend in a spiral to the right. For this reason tapping cuts usually ascend to the left to cut more tubes. :up:
http://sy0301braindump.wordpress.com/
http://70640microsoftcertification.wordpress.com/
http://640822ccnastudy.wordpress.com/
PostPosted: Mon May 13, 2013 10:30 pm
I have no idea what your comment means. :noidea:
PostPosted: Thu May 16, 2013 10:35 am
Bad Google translate?
My Renovo R1 wooden bike project
Check it out: the most amazing vintage Colnago, Merckx and Pinarello collection
Users browsing this forum: No registered users and 3 guests
There are no new unread posts for this topic. Latex tubes with Dura Ace 9000 c24 wheels
Horacio
7
886
Tue Jan 01, 2013 3:38 am
Horacio View the latest post
There are no new unread posts for this topic. Latex failure
Szczuldo
25
1733
Tue Oct 02, 2012 5:14 am
markyboy View the latest post
There are no new unread posts for this topic. Ultegra Ui2 E tubes
pjs
Wed May 22, 2013 2:28 am
pjs View the latest post
There are no new unread posts for this topic. Help...the lightest 1.30-1.50 tubes ?
in MTB
spOOn1965
Mon Apr 29, 2013 7:43 pm
Gregorio View the latest post
There are no new unread posts for this topic. Light reliable tubes?
in MTB
nrsnow
9
815
Fri Jul 20, 2012 2:51 am
nrsnow View the latest post
It is currently Wed May 22, 2013 7:55 am
