Post new topic Reply to topic  [ 14 posts ]
PostPosted: Tue Dec 18, 2012 3:19 pm
Girlfriends Crux Carbon Disc in at 15.7lbs 7.121kg
Stans Race Gold wheel set
Sram Red
PostPosted: Tue Dec 18, 2012 5:02 pm
wow very nice!
how much does the wheels weight?
PostPosted: Tue Dec 18, 2012 10:11 pm
Stans Race Gold 1390g
disc-75g each
Challenge Grifo 335g each
set up tubeless.
PostPosted: Tue Dec 18, 2012 10:21 pm
Sweet bike!
PostPosted: Wed Dec 19, 2012 3:15 am
When you brake how close are the levers to the bar?
PostPosted: Wed Dec 19, 2012 2:58 pm
With the Hayes CX-5 I can adjust the throw to almost right as you touch the lever (pads not rubbing the rotor) or almost to the bar, pending on how you adjust the pads and cable to your feel on how much lever action you want to apply for braking. I’ve had the BB7’s before my opinion these are a lot better all around.
PostPosted: Wed Dec 19, 2012 3:47 pm
Hmmm, interesting. Thank you.
PostPosted: Wed Dec 19, 2012 4:22 pm
great, thanks for the details
PostPosted: Tue Jan 29, 2013 2:44 am
Sick bike, about 3.5lbs lighter than my Crux.
PostPosted: Tue Jan 29, 2013 11:55 am
Here is mine new Crux carbon Disc 52cm.
Red shifters
Red front der.
Force rear der.
Force Chain and casette 11-28
Red cranks 46-36
3T Ltd Palladio seatpost
SLR Ti saddle
3T Ergonova Team bar 42cm
3T Team stem 100mm
Shimano BR-CX75 brakes
Mavic Crossmax ST Disc wheels
King gage
Race Ware Direct 500 mount
Crank Brothers Twin Ti pedals
7.950kg +-10g ready to ride weight (with new pedals and casette about 7.780kg)
PostPosted: Sun Mar 17, 2013 12:14 am
What size rotors are Crux disc owners running in the front? I'm building up a 2013 Crux Carbon Pro and I'm finding that I can't get a 160mm rotor into the caliper when I mount the Avid BB7 caliper directly in the post mount. This makes me suspect the fork is sized for a 140mm rotor. Guess I need an adapter from Avid to use the 160mm rotor?
PostPosted: Sun Mar 17, 2013 1:06 am
Shop Wrench
You dont mount the bb7 directly to the fork. You must use the CPS washers. Two under and two over the caliper, per bolt.
PostPosted: Sun Mar 17, 2013 3:42 pm
Amazing looking bike!
PostPosted: Mon Mar 18, 2013 7:09 pm
Yes, the issue I describe above is with the the CPS washers in place. Do you know the answer to my question?
Users browsing this forum: Google [Bot], spytech, steff and 21 guests
There are no new unread posts for this topic. Crux Carbon Disc 52cm
Tracerboy
9
1159
Fri Feb 01, 2013 5:30 pm
CBJ View the latest post
There are no new unread posts for this topic. Specialized Crux Fork - Replace with the disc fork version?
in Cyclocross / Touring
EnzioL
Fri Oct 12, 2012 9:49 am
scottyroyal View the latest post
There are no new unread posts for this topic. Specialized CRUX Elite Frameset - CX - New, never ridden, 52
prendrefeu
Wed Mar 27, 2013 5:44 am
prendrefeu View the latest post
There are no new unread posts for this topic. 2011 Crux 52cm
thisisbenji
Tue Jan 29, 2013 1:57 am
thisisbenji View the latest post
There are no new unread posts for this topic. 2012 Trek Madone 5.2 & 2011 Spec Crux Elite
DividedVolta
Thu Mar 07, 2013 10:32 pm
DividedVolta View the latest post
It is currently Sun May 19, 2013 8:28 am
