It is currently Thu Jan 19, 2017 8:06 am
Post new topic  Reply to topic  [ 2 posts ]
 Post subject: XT Cranks for Cross
PostPosted: Mon Dec 10, 2012 4:01 am
Of my two Ridleys that i race (40/46T front, 38/44T front) both 130b, i would like to use a 28/40T XT crankset for some of the steeper climbs in the area for training and riding. I do not want to change cassettes (12-27T) and i am running SRAM Force rear derailliers and shifters. What front deraillier would work? Thanks
 Post subject: Re: XT Cranks for Cross
PostPosted: Mon Dec 10, 2012 4:16 am
Does you frame require a braze on mounted front derailleur? If NOT, then you could go for a sram XX band mount front derailleur, it would be ideal for those ratios. If it does take a braze mounted derailleur, you may run into trouble. The XT crank rings are likely too far from the frame for most road front derailleurs to reach.
Does your Ridley have a threaded bb shell, or is it a pressfit? If it is threaded, you could juggle some bb spacers around to bring the rings closer to the frame.
There are no new unread posts for this topic. New 'Cross Tubeless
in Everything wheels
Geoff
7
664
Thu Feb 11, 2016 2:55 pm
Geoff View the latest post
There are no new unread posts for this topic. Best cables for cross
airpoppoff
Sun Jan 01, 2017 9:52 pm
mattr View the latest post
There are no new unread posts for this topic. Rapha Cross shoes almost new 44.5
ultyguy
Thu Oct 20, 2016 7:40 pm
ultyguy View the latest post
There are no new unread posts for this topic. Campy Shamals for cross?
velomane
9
644
Sat Feb 13, 2016 4:33 pm
stormur View the latest post
There are no new unread posts for this topic. Cube Cross Race SLT
jmaccyd
Wed Dec 14, 2016 1:37 pm
ediri View the latest post
Users browsing this forum: No registered users and 5 guests
