Post new topic Reply to topic  [ 21 posts ]
Go to page 1, 2  Next
PostPosted: Fri Oct 05, 2012 1:02 am
I am currently using a headset spacer cable cross bike. I would like to slam my stem all the way down. I was wondering if anyone has any experience with drilling their stem as a cable stop. I was talking to the Thomson rep at gloucester and he said that if you drill in through the side and out through the bottom, that it passed their fatigue tests. Not sure if this would be true with all stems or if anyone has any experience with it. I have a Ritchey WCS 4-Axis stem. On my pit bike I have a Cannondale OEM C3 stem (125 grams!) My pit bike doesn't need to be slammed, but I would prefer it.
My Bike:
viewtopic.php?f=10&t=110318" onclick="window.open(this.href);return false;
PostPosted: Fri Oct 05, 2012 2:13 am
Just go mini-V?
PostPosted: Fri Oct 05, 2012 3:10 am
If the thomson stem passes their fatigue tests with two holes drilled in the middle of their extension, then every one of their stems should come with those holes predrilled. Theyre clearly not trying hard enough.
PostPosted: Fri Oct 05, 2012 1:23 pm
You can call Thomson and ask for a diagram on where to drill.
Not everyone has cantis
PostPosted: Fri Oct 05, 2012 2:52 pm
Could you not just use a fork mounted hanger, such as the Kinesis RC09 hanger?
FELT AR0
Velo Club Bristol
PostPosted: Fri Oct 05, 2012 5:28 pm
Unfortunately not, my fork is carbon monocoque and therefore I cannot bolt through it
My Bike:
PostPosted: Sun Oct 07, 2012 9:03 am
What about the FSA headset.
Or the Ritchey one
PostPosted: Tue Oct 09, 2012 2:41 am
i kinda meant that they should drill their stems for weight savings, or thin out the walls, etc.
PostPosted: Tue Oct 09, 2012 4:54 am
"if you drill in through the side and out through the bottom, that it passed their fatigue tests"
A little strange a stem with hypothetical holes in a conversation could pass actual tests. Tests actually mean tests, and not talk.
PostPosted: Tue Oct 09, 2012 5:51 pm
The thomson representative said that he drilled holes in one of their stems and then put it through their fatigue tests. It was not hypothetical, sorry for the confunsion.
Regarding the using a headset cable stop, That is what I am using. The issue is that the housing bend is very severe, so the brake feels like trash, and I want to put my stem even lower, aka no headset spacer cable stop.
My Bike:
PostPosted: Wed Oct 10, 2012 12:02 pm
Some people in your situation offset the cable stop to one side for housing clearance, and readjust the brake accordingly. Not a perfect solution, but its better.
PostPosted: Mon Oct 29, 2012 10:10 am
This is what I will be doing when my cross bike finally comes together.
PostPosted: Mon Oct 29, 2012 8:38 pm
I offset it over the stem and the hanger is like at one o'clock.
PostPosted: Tue Oct 30, 2012 4:04 am
Does that stem have an extra ridge along the top of the extension, or is the light playing tricks on me?
PostPosted: Wed Oct 31, 2012 8:24 am
The article that I pulled that from said only this:
"This Thomson stem was drilled out by JC Breslin, one of his sponsored racers. He put it in a drill press and says he’s run it for a couple seasons with no issues."
Post new topic Reply to topic  [ 21 posts ]  Go to page 1, 2  Next
Users browsing this forum: No registered users and 2 guests
There are no new unread posts for this topic. Which stem?
BeeBee30
Fri Jun 01, 2012 7:52 am
SWijland View the latest post
There are no new unread posts for this topic. stem
in MTB
cycleforlife
9
1266
Mon Jun 11, 2012 10:54 am
skyshine View the latest post
There are no new unread posts for this topic. HED GTO Stem/Bar
micropox
Sun Jul 22, 2012 9:39 am
micropox View the latest post
There are no new unread posts for this topic. Attachment(s) Which Road Stem
hoggy
10
1426
Wed May 30, 2012 6:55 pm
Camilo View the latest post
There are no new unread posts for this topic. AX Zeus Stem Help
in MTB
nogueira.nuno
Fri Sep 14, 2012 9:05 pm
nogueira.nuno View the latest post
It is currently Mon May 20, 2013 1:44 am
