Post new topic Reply to topic  [ 6 posts ]
 Post subject: MTB to Cross conversion
PostPosted: Sun Nov 27, 2005 9:06 pm
I have a 1996 Schwinn Moab S Cro-Mo frame that I am looking to convert to a cross rig. I read C+ (Cycling Plus) the other month and they had an article about this. Is it as involved as cutting the canti posts and having them reattached? Is there a mechanical way of solving this? Any pitfalls I should look out for? Thanks in advance!
-efwd
PostPosted: Sun Nov 27, 2005 10:06 pm
-efwd
Before you start cutting or buying anything;
    Does the rear triangle take a cross wheel? I put Cross wheels in my MTB for winter use. My rear 30mm Tufo Tubular Clincher has only 5mm clearance to the bridge between the chainstays. That is not a lot!
    Does your fork take a Cross wheel? Put in a road wheel to check!
I have disc brakes, so I do not have the brake boss position issue. Maybe somebody else can comment on ways to solve that.
 Post subject:
PostPosted: Sun Nov 27, 2005 11:22 pm
Hi
I did see this one, and it surprised me
http://www.speedgoat.com/product.asp?pa ... &brand=155
only the max. suggested tire with is 25mm so that will be a problem when having a cross tire.
it's a simple sollution for the problem though.
Bas
 Post subject:
PostPosted: Sun Nov 27, 2005 11:51 pm
paul motoBMX brake is a very simple and elegant looking solution. I have no idea how well they work, though.
http://paulcomp.com/
 Post subject:
PostPosted: Mon Nov 28, 2005 2:31 am
Thank you for the suggestions. Gives the clearance issues with the Mavic Adapter, it seems as though the motoBMX is the better solution, albeit more expensive... Do y'all know of any other things of which I need to be made aware regarding converting this old mtb to drop-bars, cyclo-x wheels, etc.? Thanks again!
-efwd
 Post subject:
PostPosted: Tue Nov 29, 2005 1:15 am
If the Moab fit you well as a mountain bike you will probably need a much shorter stem when using drop bars to compensate for the forward reach of the bars and brake hoods. At least I had to when I did something similar.
If you do end up going with the motoBMX brake please post your impressions of how well it works for you.
Users browsing this forum: No registered users and 5 guests
There are no new unread posts for this topic. HED Conversion
Enda Marron
Thu Apr 25, 2013 4:18 am
There are no new unread posts for this topic. SS conversion on a budget
in Cyclocross / Touring
headwind816
Tue Nov 20, 2012 10:11 pm
allezdude View the latest post
There are no new unread posts for this topic. Tune Prince X-12 conversion
in MTB
Matti
Wed Nov 14, 2012 8:46 am
Matti View the latest post
There are no new unread posts for this topic. FFWD disc conversion kit
in Everything wheels
Kasparz
Sun Apr 14, 2013 5:58 am
sigismond0 View the latest post
There are no new unread posts for this topic. BB86 to ISIS conversion? Anything out there?
pawnii
9
507
Tue Jan 29, 2013 12:57 am
pawnii View the latest post
It is currently Fri May 24, 2013 6:58 am
