It is currently Wed Jan 17, 2018 2:37 am
Post new topic  Reply to topic  [ 78 posts ]  Go to page Previous 1 2 3 4 5 6 Next
 Post subject: Re: Time iclic2 pedals
PostPosted: Sun May 06, 2012 8:14 pm
Rush wrote:
Ok so I'm going to buy a new bike soon. I don't want to have to buy another pair of shoes/cleats so I want to keep the same system as on my current bike.
However, the pedals/cleats on my current bike are over 10 years old and are obsolete (Time Equipe system). So I'm going to need two new sets of pedals.
Having read this thread it seems that feelings are mixed between the new iClic 2 system and the older RXS system.
I'm considering buying the bottom-of-the-range model for my current bike (which will become a dedicated commuter) and a flashier version for my new bike.
I'm going to stick with Time as I switched from Look after about 5 years or so and I like the feel of the time pedal float.
Here are the contenders:
Time RXS First : About $65, 260 grams.
Time RXS Carbon : About $150, 240 grams.
Time RXS Titanium : About $300, 190 grams
Time iClic 2 : About $100, 264 grams
Time iClic 2 Carbon : About $170, 235 grams
Time iClic 2 Titanium : About $300, 187 grams
Any experienced Time users want to chip in with an opinion?
Had a similar problem to you when I got a new bike 3 years ago - kept swapping my pre-RXS pedals between bikes until last yr when switched to Shimano DA. They are excellent ! Got a pair of cheaper Shimanos for winter bike. Float feels same but clickin is more precise. Sweet bearings too
PostPosted: Tue May 08, 2012 10:21 pm
RE : Titanium axle models. Are their weight limits for the RXS model? The manual for the iClic version states a weight limit of 90 kg (I'm 88 kg at the moment).
PostPosted: Thu May 10, 2012 4:24 am
Well I just spoke to the Australian distributer. He basically said that the weight limit was provided to
1) Protect from US-style litigation
2) Was more to do with the click-in system itself rather than the axle.
i.e. the carbon blade in the iClic pedal was often broken by large heavy brutes stamping on the pedals to click in (which you have to do with a metal spring).
This would be why the RXS has no stated weight limit but the iClic does
PostPosted: Sat May 12, 2012 10:46 am
My Iclic2 cleats are now 1000km's old, no big wearing marks.
Scott Foil Ultegra Di2
Scott Scale 35 26"
Scott Spark LTD 29" M8000
PostPosted: Thu Jun 14, 2012 9:24 pm
My own experience with the iClic2's - the partial click-in thing from the original iClic's still happens but happens less frequently. This does not make it less annoying. The pedals feel "tighter" under hard use/sprinting than the original iClic's . . . but the new metal wear plates that they added to stop/slow the surface wear on the pedals have already fallen off on one side of one pedal and are starting to on the other one - they are "glued" on not screwed on like the Shimano SPD-SL design
fix one design problem and create another - I am sending them back under warranty - but I am probably done with Time pedals. I am using a pair of used Ultegra pedals from a friend now
PostPosted: Fri Jun 15, 2012 9:20 am
How much have you ridden with these pedals before the plates started to fall off?
Scott Scale 35 26"
PostPosted: Thu Jun 21, 2012 11:11 am
Mine are 210 days old and 5000K... Pedal looks new, but cleats are pretty worn... Walked 2-3K thx to a flat.... :( Guess its ok, but worse than RSX.
PostPosted: Tue Jun 26, 2012 11:21 pm
Omiar wrote:
Afaik the RXS's are prone to breaking, the front tends to break off.
I bought the Time iClic 2 Titaniums. A bit overpriced, bit I wouldn't change them for anything else.
This is a known issue with the RXS' that was fixed.
I really like the iClic 2's which have none of the issues of the original iClics, like false clip in, wear on the pedal face, or easily broken cleats.
However I just tried Speedplays and love them. The free float in all directions is far preferable to the iCli self reentering especially to my trashed left knee.
 Post subject: Time iclic2 pedals
PostPosted: Wed Jun 27, 2012 1:19 am
I'm the opposite, for myself the Time's have more platform stability & more than enough float...Speedplay cleats are awful IMO...
"It's not the destination...it's the ride!"
PostPosted: Tue Jul 17, 2012 5:43 pm
Well - As I had noted I have the iClic2 Carbons and the "wear plates" that they added had fallen off on one side of my right hand pedal. I sent them back under warranty and they were actually pretty quick to replace them BUT now the wear plate on the 2nd pair of pedals has already come loose #@$#!
I had maybe 1,000 miles on the 1st set and less than 200 miles on the 2nd set before the plate failed !! - - and I actually like these pedals otherwise - frustrating
PostPosted: Thu Jul 19, 2012 2:20 am
Bummer!
I was going to get a set of iClic 2 Racers for my training bike but instead might get my RXS's serviced if I still can or god forbid possibly get some Dura-Ace...
PostPosted: Fri Jul 20, 2012 6:58 pm
My Iclic2 Titan right pedal has almost completely seized after around 200 miles. I'm sending them back since you are not supposed to strip yourself. Anyone else had this?
PostPosted: Sat Jul 21, 2012 2:39 pm
I had the iclic 1 when they first cameout , liked them but didn't love them.
Went to LOOK Ti blades , love them until now they squeek non stop and have play in the spindle and the body.
So what next for me? 2006 RXS Ulteam titanium i guess
2012 KUOTA KOM Team Edition Campag SR11 .....My mistress
2012 RIDLEY HELIUM being built up ....
PostPosted: Sat Jul 21, 2012 3:31 pm
A friend of mine had the top section of his low end Time Iclic pedal broke off at the start of a competition weekend. At first he thought his cleats were worn, but after closer inspection a part of the pedal has simply broken off. Despite the broken pedal, he still beat me.
Don't you just love those new Time pedals :? . Love the RXS by the way!
My Renovo R1 wooden bike project and the reason for my passion for all that is wood.
Check it out: the most amazing vintage Colnago, Merckx and Pinarello collection
PostPosted: Sat Jul 21, 2012 3:53 pm
SWijland wrote:
... a part of the pedal has simply broken off. Despite the broken pedal, he still beat me.
Did he waste you in the climbs? If so, it was probably the weight savings from the broken off part. :beerchug:
There are no new unread posts for this topic. Time XPro pedals - any details?
BdaGhisallo
34
3343
Wed Jan 03, 2018 11:10 pm
AJS914 View the latest post
There are no new unread posts for this topic. pedals advice?
Musiker
10
1520
Sun Jan 07, 2018 9:01 pm
IrrelevantD View the latest post
There are no new unread posts for this topic. Powertap P1 Pedals
mattCSUK
Fri Feb 24, 2017 5:41 pm
Butcher View the latest post
There are no new unread posts for this topic. Power2max vs powertap pedals? Help!!
TurboTommy
7
1133
Fri Mar 17, 2017 7:55 pm
TurboTommy View the latest post
There are no new unread posts for this topic. Dura ace pedals - Ti spindles
paulkilroy
15
1503
Sun Aug 20, 2017 6:49 pm
RJKflyer View the latest post
Users browsing this forum: bouds, praem and 33 guests
cron
