It is currently Tue Jan 23, 2018 3:33 am
Post new topic  Reply to topic  [ 479 posts ]  Go to page Previous 128 29 30 31 32
PostPosted: Sat Aug 10, 2013 10:08 am
It's just my first post but after reading this topic i just bought a racewaredirect mount for my Garming Edge 500. I will post a picture and my opinion when i recieved the mount.
PostPosted: Sun Sep 15, 2013 1:57 pm
does the original raceware mount work with a garmin 510?
2012 Scott Foil Premium
PostPosted: Sun Sep 15, 2013 2:43 pm
Works fine... I broke 2 RWD mounts when going over bumps with my carbon ergonova bars, so go careful if your running carbon bars. Don't over tighten the tension nut... My first 510 got run over when the first RWD mount let go... My second was saved by the tether strap! I'm now running one of tilquists alloy mounts.. No probs now!
PostPosted: Mon Sep 16, 2013 12:48 pm
thanks that's the exact answer i was hoping for :)
I wanted a tilquist alloy mount too but he was out of stock for a 3T ARX LTD stem a while ago.
PostPosted: Mon Sep 16, 2013 4:30 pm
I have the LTD Mount now :-)
Send me a mail ;-)
See all my bike h e r e
PostPosted: Sun Sep 22, 2013 7:06 pm
Wow, who'd have thunk it that what would seem to be a simple thing like getting the perfect mount would be so complicated? From browsing this and other threads, it seems there's tonnes of different options and it's hard to keep up on which ones are the latest, pros and cons of each, so I'd really appreciate some current advice.
I'm looking for a mount for my Garmin Edge 500 for my road bike (31.8mm FSA K-Force carbon monocoque bars) and my TT bike (3T Pro alloy aero bars). On the road bike, I'd like the Garmin positioned a little in front of the stem and on the TT bike, I guess in between the aero bars would be ideal?
Which option is best for these positions and is also light and reliable (I'd rather pay a few quid extra and not have to worry about it possibly falling off and destroying my Garmin)? Thanks!
PostPosted: Mon Sep 23, 2013 12:16 pm
Just got my 510 and at first it seems to fit perfectly on the original RWD mount...but the 510 sits so close to my 3T ARX LTD stem that any bump i hit makes the two rub together and gives you a annoyingly loud vibration sound.
Looks like I'm in the market for a new mount.
What's the best???
PostPosted: Mon Sep 30, 2013 4:00 pm
It took an awful lot of time that they came up with this.
PostPosted: Mon Sep 30, 2013 5:28 pm
The problem (as I see it) with the mounts that involve the stem itself, either bolted to the faceplate or on the faceplate, is that while they may be beautiful piece of craftsmanship they are also subject to the angle of the stem & headtube. With a mount that utilizes the handlebar and is free to rotate, such as the RWD one, you can adjust the angle not only give a better viewing angle for you (and we're all different!), it may also be a little bit more aero heading into the win(d).
So if you've got your stem angled up, which some people do, then the Garmin's angle is affected as well, and it presents a larger surface area into the wind.
PostPosted: Mon Oct 07, 2013 4:12 pm
I see your point but the angle of the faceplate on most stems is 90deg to the horizontal... Therefor the garmin should be in an ideal viewing position if your bike position is setup appropriately...
I run tillquists mount on both my 3T -17 and -6 degree stems and both are in the identical (ideal) viewing positions...
PostPosted: Mon Oct 07, 2013 6:01 pm
Ave, is that mount/stem plate (which stem is it?) commercially available?
PostPosted: Mon Oct 07, 2013 6:26 pm
Look at Barfly Mount Web-site
PostPosted: Mon Oct 07, 2013 7:27 pm
Ah thanks, found it!
I still prefer your mount. ;)
PostPosted: Mon Oct 07, 2013 7:30 pm
Thanks 8)
There are no new unread posts for this topic. K-Edge Garmin Mount - Regular vs XL
ipenguinking
9
866
Thu Dec 28, 2017 7:22 pm
dim View the latest post
There are no new unread posts for this topic. Out-Front Mount Request - to hold a Garmin 500 & Bontrager Ion 700
Matt28NJ
Thu Jan 26, 2017 3:56 pm
SpecializedColnago View the latest post
There are no new unread posts for this topic. Converting flat mount to post mount
Miller
Wed Mar 01, 2017 11:55 am
Broady View the latest post
There are no new unread posts for this topic. go pro mount seat post
nohands
Sat Jul 15, 2017 5:28 am
mpulsiv View the latest post
There are no new unread posts for this topic. Canyon H31 mount screw
Kristian78
Sun Sep 10, 2017 7:59 am
MayhemSWE View the latest post
Users browsing this forum: alcatraz, Baidu [Spider], Bing [Bot], Google Adsense [Bot], hannawald, praem, Zitter and 42 guests
