Shimano 7900 bar clamps..
Frankie - B
Administrator
by Frankie - B
I'm on board with the cf clamps. I weight between 80 an 85 kilo and would trust the cf ones better then alloy ones.
Sent from my HTC.
andy2
by andy2
What Frankie said.
I've been on the BTP carbon clamps on several bikesfor a few years. One case in point, 85kg on a cross bike that I just had a look at and they're perfect.
Way these things work they are in tension when mounted, so cf is actually the perfect material.
/a
rolobikes
2ndgen
by 2ndgen
5 8 5 wrote:2ndgen, that links for Ti model - same part no?
:thumbup: Yes sir.
5 8 5
by 5 8 5
Bit confused 2ndgen. You said you had some info on the aluminium clamps?
thisisatest
by thisisatest
shimano doesnt make aluminum clamps.
2ndgen
by 2ndgen
5 8 5 wrote:Bit confused 2ndgen. You said you had some info on the aluminium clamps?
Did I? I must've mixed that up with another topic I was posting on.
I'm looking into a fr der clamp replacement in aluminum.
5 8 5
by 5 8 5
2ndgen, you are correct. It was late, I was tired...............soz :lol:
2ndgen
by 2ndgen
5 8 5 wrote:2ndgen, you are correct. It was late, I was tired...............soz :lol:
No worries. :thumbup:
SL58
by SL58
I used Ti t-bolt and Alu. nut with existing setup. Total weight is heavier than BTP but equal
to Shimano even though steel band was there. A lot cheaper though.
CAADEL
by CAADEL
2ndgen wrote:http://www.ebikestop.com/shimano_st_7900_sti_lever_clamp_band_unit-LD7756.php?PARTNER=GOOGPS
Shimano ST-7900 STI Lever Clamp band Unit
MFR's Part #: Y6RT98130
$110./pr.
You're better off getting the Ti versions.
Are the bolt and nut made of titanium too or just the band?
Neoryan7
by Neoryan7
the t-nut with the titanium band is about is more or less 1 gram lighter than the ones that come with the steel band. I upgraded my ultegra di2.
titanium band=6.7g t-nut=2g
steel band=9.5g t-nut=3.4
Saved 4.2 grams per shifter.
uraqt
by uraqt
Neoryan7,
Thanks for posting, There are new TI lighter bands for 9000, but nobody has confined with pix. Just from the Shimano part #'s
C
Neoryan7
by Neoryan7
The new ones look more heavily machined than the 7900 series ones.
drainyoo
by drainyoo
Anyone have real weights for these, and are the nuts and bolts titanium as well?
indywagon
by indywagon
I stripped one of mine a while back and wound up purchasing what turned out to be a bag five, I think. Somewhere in the garage, I still have four. Let me know if you're interested.
Chris
