It is currently Tue Jan 16, 2018 12:42 pm
Post new topic  Reply to topic  [ 216 posts ]  Go to page Previous 19 10 11 12 1315 Next
PostPosted: Sun Apr 08, 2012 9:10 pm
huge pic.
http://i.minus.com/i0NF23fnLCQ28.jpg
α
PostPosted: Mon Apr 09, 2012 5:41 am
Shop Wrench
adriano wrote:
huge pic.
http://i.minus.com/i0NF23fnLCQ28.jpg" onclick="window.open(this.href);return false;
I'd stay away from WW rotors on the road. Did you see the bikerumor article? TRP and Volagi are blaming it on the use of WW rotors that don't dissipate heat well enough.
I'm so rubbish at this.
PostPosted: Mon Apr 09, 2012 8:51 am
Epic-o wrote:
arbitrage wrote:
Cool--thanks for the details. Out of curiosity, where did you find these numbers?
Own calculations
Can you please post these?
Thanks,
I
PostPosted: Mon Apr 09, 2012 11:44 am
i havent had problems, but the most i can descend around here is 400 feet. as cool as these are, im not opposed to going back to th stock bb7 rotors or some dh tested stuff.
α
PostPosted: Mon Apr 09, 2012 1:29 pm
Illuminate wrote:
Epic-o wrote:
Own calculations
Thanks,
I
Pretty simple
Without considering wind drag and assuming constant wheel angular speed, emergency braking (around 0.6g) results in 540N in the contact between the ground and the tire (F=m·a). Considering that the weight distribution is 70-30 and the wheel radius is 0.35m, the braking moment is M=F·w·Radius=540·0.7·0.35=110Nm
For the standing start, a 600Nm peak torque in the crankarms is 600·(drivetrain ratio)=600·13/52=150Nm in the freehub pawls
http://cds-0.blogspot.com
PostPosted: Mon Apr 09, 2012 5:22 pm
I disagree with your calculations.
1. Braking.
Emergency braking means there is no such thing as weight distribution - around the tipping point at 0.6g all the weight is on front wheel, so it means torque is 540*0.35=189 Nm
2. Pedaling
When was the last time when you saw Chris Hoy doing a full gas standing start on a 24-spoked road carbon wheel with a freehub? A 36-spoke track wheel with a fixed gear is more like it...
So for a road wheel a more extreme real-life scenario is climbing a very steep short hill, let's take a 20% one for example. Let's assume the same 90 kg rider (+7 kg bike) who is putting out 700 Watts during this short effort. He is going up at 3.57 m/s, wheel circumference is 2.1 m, so wheel angular velocity is Va=2*pi*3.57/2.1=10.676 and torque is 700/Va=66 Nm
So, braking torque is roughly 3 times higher than pedaling torque.
PostPosted: Mon Apr 09, 2012 6:15 pm
Fascinating maths. Now I'm 70 kg. I averaged 60 nm up a 13 minute climb last week with peaks over 80 nm. I didn't get anywhere near 700 w. when I do I find it easy to break traction on the rear wheel Much harder to do so under braking. Somehow this doesn't seem to fit in with the maths. Ideas?
PostPosted: Mon Apr 09, 2012 6:43 pm
You must be talking torque at cranks, not rear wheel.
PostPosted: Mon Apr 09, 2012 6:56 pm
1. Braking.
2. Pedaling
So, braking torque is roughly 3 times higher than pedaling tortue.
I have considered that both brakes were actuated during the emergency braking, intelligent riders doesn't brake only with the front caliper. Your assumption of all the weight on front wheel depends of many factors (COG height, inertia and the braking moment in each wheel) so I wouldn't say that my calculations are wrong.
Chris Hoy numbers are an extreme example, obviously he's not the average cyclist
You have also to consider that pedalling loads are continuous and braking ones aren't. Anyway, some simplified calculations to give a first order of magnitude
PostPosted: Mon Apr 09, 2012 6:59 pm
Ah yes I am. But I recall my friend measuring around 10% less if that with similar peaks using a Powertap. He weighs less than 60 kg
PostPosted: Mon Apr 09, 2012 7:14 pm
Well, you can brake with both brakes, but emergency braking = braking at or very close to tipping point = all weight is on front wheel. And you can't really brake at 0.6g with 70/30 weight distribution on a road bike. Maybe if you go all the way behind the saddle, but I still doubt it.
BTW, these are just some real life examples of the loads. I don't know torque limit manufacturers design their road wheels around. Maybe they can withstand 150 Nm, maybe not.
PostPosted: Mon Apr 09, 2012 7:45 pm
Using 67 kg (rider+bike), same 20% slope and 300 Watts you'll have torque of 45 Nm at rear wheel. So, yeah, kind of hard to believe in 60 Nm average.
Just so you know, at 60 Nm at pedals and 70 rpm cadence, one is producing 440 Watts irregardless of his weight.
PostPosted: Tue Apr 10, 2012 8:07 am
I could send you the files. Cadence was around 40 as the average gradient was 17% with pitches at 30%. It's the Bastille at Grenoble. Gearing was 36 x 25.
PostPosted: Tue Apr 10, 2012 8:46 am
It changes things considerably: 60 Nm and 40 rpm equals 250 Watts, which is quite reasonable.
And with 36x25 torque at rear wheel was 42 Nm.
PS. climbing at 40 rpm for 13 minutes - you must be tough. :thumbup:
PostPosted: Tue Apr 10, 2012 10:39 am
Let's see. The UCI has already been secretly approached by SRAM who secretly have a fully functioning road hydraulic system already developed. Oh and the UCI is going to informally review this summer disc brake usage for road cycling competition starting as early as 2013. Shimano, at least, have a functioning cable-actuated road disc brake. No word on if they are secretly developing a road hydraulic disc brake system. Umm, let's see. Campagnolo has eschewed disc brakes, and of course they would. Since they don't develop any MTB components, they don't even have a MTB disc brake system. So, they are not in a good position.
Frame manufacturers are already incorporating disc brakes into future models. Specialized has a road disc brake road bike, secretly of course. This should be introduced as part of their 2013 ine. I guess they weren't too happy with Volagio beating them to this market given that the Volagio founders were past Specialized employee nobodies.
2013 is going to mark the beginning of the end of caliper brakes on road bikes.
There are no new unread posts for this topic. Road Disc Brakes- Rotor Choice
[ Go to page: 1 2 3 4 5 ]
mdeth1313
73
7031
Fri Jan 12, 2018 12:57 am
simoncx View the latest post
There are no new unread posts for this topic. Attachment(s) Why is no one using disc brakes in the tour?
[ Go to page: 19 10 11 12 13 ]
gceniza
186
17972
Sat Jul 22, 2017 8:29 am
lobuxracer View the latest post
There are no new unread posts for this topic. Disc brakes : new pads = brake rub??
Delorre
9
1096
Mon Oct 23, 2017 11:36 am
CBJ View the latest post
There are no new unread posts for this topic. Attachment(s) In a 2017 ww world - what is the weight penalty of running disc brakes?
alcatraz
Sat Mar 18, 2017 5:53 pm
nemeseri View the latest post
There are no new unread posts for this topic. Attachment(s) Cannondale 2018 road bikes
[ Go to page: 17 8 9 10 11 ]
DannyB9
151
44304
Fri Dec 22, 2017 3:33 pm
kooching View the latest post
Users browsing this forum: Bing [Bot], gewichtweenie, liam7020, sungod, Yahoo [Bot] and 43 guests
cron
