It is currently Thu May 25, 2017 4:28 am
Post new topic  Reply to topic  [ 94 posts ]  Go to page Previous 13 4 5 6 7 Next
 Post subject: Re: Chain Cleaning
PostPosted: Wed Feb 15, 2012 3:41 am
Prolink is great, put some on go for a ride, get home run chain through rag until dirt stop coming off, put more prolink on go for another ride. Quick, easy and works.
all this messing around with degreasers and chain cleaners is a waste of time and often does more harm than good.
BUT Prolink in the wet is rubbish, have to go for finish line cross country then but same process
PostPosted: Sat Feb 18, 2012 10:14 pm
I have to add my two cents... The chain operates as a component in the drive train, interacting with the most force on the cassette, then the chainwheels, and a very little amount with the derailleur pulleys.
Chains are inexpensive compared to cassette and chainrings. More importantly, they are more likely to have a catastrophic failure that may result in serious injury. That being said, I agree with those that regularly replace their chain prior to it being worn out. The use of several chains in a rotation is problematic, especially considering the need to reinstall the chain with a new pin or link to retain structural strength, not to mention in the proper orientation to ensure it meshes correctly with the (now) worn-in cassette and chainwheel.
I am not sure if people understand that "chain stretch" is the result of mechanical wear, not the metal links of the chain deforming. As the pins and sideplates grind away at each other, a small amount of wear-induced slop is produced at each interface, that over the total length of the chain is measured as "stretch". See other threads about measuring this stretch, as the Park device seems to have issues. Use an accurate shop ruler or calipers is the best method.
Don't cheap out - buy new chains regularly and save your cassette, chainwheels, shifting precision, and perhaps some of your skin if you avert a broken chain.
I also advocate lubing after each ride by wiping the chain off with a clean cloth, lubing the inside of the chain (I use Triflow because it works fine and is cheap), and wiping off the excess lube and dirt. Let sit till the next day (ride) and wipe off again. Now go ride, like I plan to right now...
1984 Ciocc Aquila 84 - SLX frame and full Campy Super Record
2006 Orbea Lobular - Aluminum and Carbon frame with Ultegra
 Post subject: Chain Cleaning
PostPosted: Thu Mar 27, 2014 1:30 am
I've tried doing searches on this topic and can't find much. What is you preferred method for cleaning chains?
PostPosted: Thu Mar 27, 2014 1:42 am
Just use mineral spirits and clean it. You can slop it on with a paintbrush and the dirt comes off as the old lube breaks down. Then wipe it down and relube. Its fast and efficient. Don't make a mountain out of a mole hill.
PostPosted: Thu Mar 27, 2014 4:04 am
My wife bought me a park chain scrubber for Christmas a while back and I love it. I loved it so much I bought another. I use the first one to run park's chainbrite cleaner through. Second, I use dial soap and finish off with straight water water. The whole process takes about 5-7 minutes. It comes out great! Park's chainbrite cleaner is expensive but it sure does work.
PostPosted: Thu Mar 27, 2014 4:16 am
I have always used ZEP Citrus Heavy-Duty Degreaser and a clean rag. You can find it at the hardware store and it's a lot cheaper than the ones at the bike store.
PostPosted: Thu Mar 27, 2014 4:21 am
Rough synthetic brush with citrus heavy duty degreaser for me too (use it for cleaning rest of the bike as well). Wash my bike and drive train once a week, so everything stays nice and sparkly.
PostPosted: Thu Mar 27, 2014 4:30 am
Drop my chain into an old water bottle filled with a bit of Rock n Roll Gold. Shake. Wipe thoroughly and reinstall.
Sometimes I'll pop a q-tip in between each link at this point, but usually skip it.
Once installed, I put a small drop on each link and wipe lightly.
I try to do it the night before.
Sub-5.8kg / 12.7lbs Addict SL w/PowerTap
9.3kg / 20.5lbs Scale 29 Pro ... woefully under-used
Retired: 5.9kg / 13lbs Addict R1 w/PowerTap ... lowest was 5.593kg / 12.33lbs
PostPosted: Thu Mar 27, 2014 10:20 am
Citrus degreaser works well with a stiff brush, won't damage your paint of anodised finishes like some heavy duty degreasers. And it is far more environmentally friendly than petroleum based products.
The Park Tool chain cleaner also works well
Ozrider - Western Australia
PostPosted: Thu Mar 27, 2014 10:44 am
i prefer to remove the chain. soak with diesel petrol, spin it inside a container and you can feel all the fine sand sinking at the container. Finally rinse it with high pressure water and leave it dry before I re-lube.
PostPosted: Thu Mar 27, 2014 11:13 am
I use Morgan Blue and spray it on a rag and wipe the chain, leave it rest for a bit, then wipe off.
Nothing else I've used comes close.
PostPosted: Thu Mar 27, 2014 12:19 pm
I use Morgan Blue chain degreaser and a stiff paintbrush. I've never seen results like bombertodd's photo though, that chain and cassette look brand new!
Campagnolo; because I ride a bicycle, not a fishing rod.
M∆SON Definition / Camapgnolo endurance & bikepacking build - ~8.4kg
PostPosted: Thu Mar 27, 2014 12:52 pm
I finally picked up a Park Took chain cleaner. I use some orange cleaner and run it through, soak it good.
Then, run a couple of fresh fills of water on the chain to get all the orange stuff off. Lube. Nice and clean.
I used to just run a rag with acetone on the chain once a week, but the gunk/grime in the links never comes out well...so switch to the soak/clean method...works like a charm and very little mess. Just need a used crappy rag to catch some extra liquid coming out of the exit part of the device.
^ozrider....same method just saw your post.
PostPosted: Thu Mar 27, 2014 4:41 pm
Both had more than a 1,000 miles on them when I took that picture. You can tell the chain is used from the silver rollers (gold wore off). They key to the Park cleaner is using their cleaner non diluted which is kind of expensive.
I've tried:
Park Chainbrite cleaner diluted
Zep degreaser
Zep heavy duty degreaser
Simple Green
Diesel
Dial soap
and a few others I can't recall
Diesel or non diluted Park Chainbrite were ten times better than everything else I tried. I don't like the idea of have to dispose of diesel so I use the Park Stuff. I also clean my cassette with a stiff paint brush and a little park chainbrite.
A clean lubed chain is fast chain! :beerchug:
PostPosted: Thu Mar 27, 2014 5:33 pm
Great information! Sorry I couldn't find this thread, and started a new one. I think Zig is correct in addressing what is left behind between the links, rollers and pins. Looks like the park tool and cleaner product is the way to go.
Thanks again! Oh and BomberTodd, you da man!
There are no new unread posts for this topic. Winter drivetrain cleaning
gitsome
23
1243
Thu Jan 19, 2017 8:14 pm
BdaGhisallo View the latest post
There are no new unread posts for this topic. Edco Monobloc : chain skip after new chain install on only 1 cog
Delorre
22
1741
Wed May 10, 2017 7:13 am
F45 View the latest post
There are no new unread posts for this topic. Standard chain rings to semi compact chain rings = new crank?
stockae92
11
839
Fri Sep 23, 2016 8:27 pm
topflightpro View the latest post
There are no new unread posts for this topic. chain?
digitalintrigue
Fri Sep 09, 2016 11:38 am
peted76 View the latest post
There are no new unread posts for this topic. Chain lubricants
[ Go to page: 15 6 7 8 9 ]
wheelsONfire
130
14301
Sat May 20, 2017 11:20 am
Francois_Viviers View the latest post
Users browsing this forum: Applesoap, Baidu [Spider], check6, fio, JoeFlan, Matt28NJ, silvalis and 27 guests
