Post new topic Reply to topic  [ 1088 posts ]
Go to page Previous  1 ... 31, 32, 33, 34, 35, 36, 37 ... 73  Next
PostPosted: Tue Jul 31, 2012 6:31 pm
I'm talking about 2012 Di2 working with Shimano MTB cassettes. Whole different ball game I think.
PostPosted: Tue Jul 31, 2012 9:29 pm
Shimano 10sp MTB cassettes have the same spacing as road. It's the derailleur cable pull that's different from road and from earlier MTB derailleurs.
PostPosted: Wed Aug 01, 2012 2:23 am
As said above, the cog spacing for 10 speed MTB and road are identical. If you can run 10speed road cassettes, you can run 10 speed MTB, provided that is the derailleur has sufficient capacity for the largest teeth.
The 9-speed MTB RD's were interchangeable with 10 speed Road RD's in Shimano's line. But not the 10speed MTB ones, which utilise a different cable pull as mentioned above.
Which is why you saw the XTR Yumeya pulley cages on the DA-9000 RD's and running 10 speed MTB cassettes. To fulfill the conditions required above.
PostPosted: Wed Aug 01, 2012 2:44 am
Which of the Sky guys was on 9070 w/ Yumeya cage? I haven't heard this from anyone at Shimano Europe. I know they're riding 9070, but not with any modification.
Wiggins was on 7970 with a modified RD cage to run a wide range CS. He could also have been running a 10sp Ultegra 12-30 CS w/out having to replace the pulley cage on his RD.
Additionally, the new 9000 series wheels come with a spacer to accomodate a 10 speed CS, which is why he was running the new C50 on the flatter stages.
Turn down the suck knob.
PostPosted: Wed Aug 01, 2012 11:06 am
tommyb wrote:
Anyone know if this is true? "You could even program them to simply make the right shifter shift harder and the left shifter shift easier, or vice versa, or really whatever."
From: http://www.bikerumor.com/2012/05/31/201 ... -unveiled/" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
I think he's written it in odd language but essentially you can programme each of the 4 levers/switches to do whatever you want it to i.e make both levers on "the right shifter shift (to a) harder (gear) and the left shifter shift (to an) easier (gear)". Obviously this would mean you couldn't shift the front chainrings but it is possible.
A Shimano rep recently showed me by reprogramming Ultegra Di2 while I was riding it on a home trainer.
Be careful though as you could have all 4 switches programmed to shift to a smaller sprocket and then never be able get back up the cassette again.... :P
PostPosted: Wed Aug 01, 2012 11:16 am
Thanks that explains it, I read it as making the feel of the shifters action harder or easier, the reason's I sold my old Di2 was the lack of feedback from the buttons, anyone know if the new version has a more solid 'click'?
Team FB page
Team Leapfrog
PostPosted: Wed Aug 01, 2012 12:18 pm
I guess this question has been asked and answered in the depths of this lengthy topic. Sorry if it is being repeated.
Can you use 10 speed wheels with the new 9000 groupset? I know you can't use an 11 speed cassette on a 10 speed wheel but otherwise would it work?
PostPosted: Thu Aug 02, 2012 12:00 pm
Wiggins running Yumeya cage and MTB cassette
PostPosted: Fri Aug 03, 2012 4:35 pm
Has anyone seen if the blue cleats (SM-SH12) are available somewhere ??
PostPosted: Fri Aug 03, 2012 6:22 pm
Shimano Benelux says they get them in week 37 (it's now week 31).
PostPosted: Fri Aug 03, 2012 7:21 pm
Any word if they are going to release hydraulic brakes?
PostPosted: Sat Aug 04, 2012 8:36 pm
I'm currently using Shimano Di2 on a 11-34T MTB cassette. On a Bike I'm using for Enduro Races. It all works flawless, except for the day when the chain guide was smashed by a rock, so whith not enough tension on the chain it bounced out of the big chainring until everything got stuck into the rear wheel. Inertia played its game and I found the RD like 100m away from where i was able to stop the bike. Even so I could reassemble the RD and now it's fully functional again (I use it as a spare)
PostPosted: Sun Aug 05, 2012 8:12 pm
That's a long wait....arg
PostPosted: Tue Aug 14, 2012 1:43 am
White Industries 11spd hubs: http://wheelworks.co.nz/white-ind-h3-shimano-11-speed/
PostPosted: Fri Aug 17, 2012 6:43 am
Would be cool if Campy made available a hub shell earlier rather than later.
Post new topic Reply to topic  [ 1088 posts ]  Go to page Previous  1 ... 31, 32, 33, 34, 35, 36, 37 ... 73  Next
Users browsing this forum: Bing [Bot], Doyler, Google [Bot], Google Adsense [Bot], KLabs, Tristan and 71 guests
There are no new unread posts for this topic. Dura Ace 9000 FD compatibility
TimmS
33
4580
Mon Mar 04, 2013 8:16 pm
Berg View the latest post
There are no new unread posts for this topic. Attachment(s) Dura Ace 9000 hubs
upside
26
4816
Wed Feb 20, 2013 7:52 am
eric01 View the latest post
There are no new unread posts for this topic. Dura ace 9000 di2 vs Campy EPS
Ufgators
Tue Sep 04, 2012 9:24 am
This topic is locked, you cannot edit posts or make further replies. Dura Ace 9000 compatibility
insightt47
Thu May 16, 2013 5:47 am
insightt47 View the latest post
There are no new unread posts for this topic. Gearing Question for Dura-ace 9000
TrekUk
22
987
Tue Apr 30, 2013 4:53 pm
TrekUk View the latest post
It is currently Thu Jun 20, 2013 11:40 am
Shimano Dura-Ace components & groupset at reasonable prices
