It is currently Tue Oct 17, 2017 4:28 pm
Post new topic  Reply to topic  [ 1116 posts ]  Go to page Previous 171 72 73 74 75 Next
PostPosted: Fri May 17, 2013 3:48 pm
Just tried a 9000 derallieur and chain with a 10 speed shimano cassette and sram red 1013 shifters and it works fine. There is a bit of chain skipping but the shifting is great. Ill update when i receive my cs-9000 cassette to confirm if the skipping is because of the worn cassette.
PostPosted: Fri May 17, 2013 9:38 pm
well it doesnt work fine then does it if its skipping, the ratios are different 10 to 11spd it will never work and you are wasting money.
Madone Five Series 2013
Shimano Dura-Ace 9000
Mavic Cosmic SLE 2013
PostPosted: Tue Jun 11, 2013 4:02 am
Anyone have a link to c50-tu and c75-tu rim weight? (tried searching)
PostPosted: Tue Jun 11, 2013 11:08 am
I recently weighted the rear C50 TU 9000 series:
PostPosted: Tue Jun 11, 2013 7:07 pm
@mpower - Was trying to find the rim only weights rather than the entire wheel.
You ridden the wheels yet?
PostPosted: Wed Jun 12, 2013 1:55 pm
rmerka wrote:
I know it hasn't been discussed in this thread for a while but, any of you folks there that have a noisy cassette would you classify the noise as a ticking sound when your applying power in just those intermediate gears that are on the carbon carrier? If so I think I might have the same issue with the 9000 series cassette.
Has there been any news on this front. I know a few of you were investigating with your LBShops and distributors. Was anything learned in terms of cause and remedy?
With Ultegra 11 coming in a few months, I am thinking it may be easiest to deal with the issue for now and downgrade to some Ultegra 11 cassettes. I don't believe that Ult 11 cassettes will have the carbon cog carriers like the DA9000 does.
PostPosted: Tue Jun 18, 2013 7:04 pm
I work at a Trek bicycle shop and I personally have issues with this cassette as well. Talking to Trek technical support, they believe the issue to be regarding the chain angle and the machining of the cogs. The tech rep there claimed using a campy 11s cassette resulted in no ticking/derailing sound under load.
For the record, I too have issues on the big (50t) and 21, 23, 25, 28 rear cog combinations under load. I have the full 9000 set up with 9000 cables/housing on a Madone 7 frameset with 40.7cm chainstay length. I have issues with my SRM 7950 crankset and the 9000 50-34 crankset set up with Dura-Ace C35 9000 wheels.
On another note, what's up with the b-tension screw? It seems to have no use since I have that sucker backed out so far out. You would think they could cut that screw by 75% to save some weight. This is for a 11-28 cassette.
PostPosted: Wed Jun 19, 2013 3:18 am
So here is m experience with this cassette issue. I purchased/installed a full 9000 group for my race bike in mid February and have put on many miles on it since then. I too witnessed the strange creaking/ticking noise when in the small chainring (39) and in the two highest gears on my 11-25 cassette (25 and 23) under load, but never had any derailing issues under load. I never had any of these issues in any other gears and never really run those two gears while in my big chainring unless I am in a demanding situation in a race where that is the only option at the time. The issues for me only lasted a month or so, maybe less and I cannot replicate the stated issues to this day. I can not remember if they disappeared after a proper cleaning of the bike or if the drivetrain just needed a break in period. I honestly think the noise arises from where the cogs are riveted to the ALLOY carrier. I really wonder how many people have taken the time to actually pull the cassette off the freehub body because the TOP TWO COGS are rivited to an ALLOY carrier. I have experienced no issue with the with the carbon carrier which includes the 21, 19, and 17 tooth cogs. I also have an 12-25 cassette on a different wheelset and have had no problem with the carbon carrier.
PostPosted: Thu Jun 27, 2013 10:00 am
On the subject of creaking cassettes, I've found that a contributory factor seems to be lockring tightness, or more specifically a reduction in lockring tightness after initial fitting.
Despite originally tightening to the full required torque, I found that the lockring was no longer at full tightness a few tens of miles after fitting. Re-tightening to full tightness appears to significantly reduce (virtually eliminate) the strange creaking.
Since I haven't had this problem with earlier Dura-Ace cassettes that comprise metallic carriers, I wonder if it is associated with the carbon carrier undergoing some kind of compression or settling-in process that results in the reduction in lockring tightness.
Freight-train groove-ride: 4'02" to 14'40" LOUD, bass right up and eyes closed!
PostPosted: Thu Jun 27, 2013 3:14 pm
I found this to be the case with my cassette. After I removed what was initially a properly torqued cassette, I inspected the rivets which appeared to be as snug as ever. I re-installed the cassette, properly torqued it and have had no abnormal sounds coming from it since.
My Cervelo R5
My Lynskey Helix
My MTB
PostPosted: Mon Jul 01, 2013 11:38 am
Relating to Foghats comment above, I have been reading this thread with interest as i'm running 9000, another chap at work happened to have this to my amusement, the very next ride I went on I to was handed some karma and had the strange noise you all talk about, I'm running 50/34T and a 11-25T cassette, this happened to me in the gears where the Titanium cogs are mounted to the Carbon carrier (17,19,21T gears) when I went to remove the cassette that was originally torqued up I found it wasn't as tight as originally torqued and took little effort to remove the lock ring.
I removed the cassette cleaned what little dirt was on there and torqued it all up again to exactly 40nm......lets see if this does cure it but I can only imagine it wont happen again for sometime.
PostPosted: Tue Jul 09, 2013 12:30 pm
I just replaced my DA7900 with DA9000 on my Z1. Rode it for the first time last weekend, and OMG!! The system is night and day compared to 7900!
The brakes are mind-blowing - definitely no need for a hydraulic system.
Also the FD is buttery-smooth.
Overall, two thumbs up; I love it :beerchug:
My Parlee Z1
PostPosted: Tue Jul 09, 2013 6:11 pm
nice! i'm in the process now of switching over. good to hear.
- AX Lightness Vial EVO D + DA9070 + Enve SES 3.4 carbon hubs
- Parlee ESX + DA9070 + THM SRM PM + Enve SES 6.7 CK hubs
- Independent Fabrication Ti FLW + Campy SR11 + Enve 3.4 CK hubs
PostPosted: Tue Jul 09, 2013 6:18 pm
I can second that. With the DA 9000 calipers, I can't imagine what is to be gained by moving to hydraulics for road applications.
PostPosted: Tue Jul 09, 2013 6:42 pm
For anyone in the UK buying the new DA stuff bit by bit like me, Merlin have good prices on a few bits at the moment.
There are no new unread posts for this topic. Dura ace 9000 rear derailleur?
sinjun
Mon Apr 10, 2017 6:02 am
richscott View the latest post
There are no new unread posts for this topic. Tips for dura ace 9000 hood replacement.
SpecializedColnago
Wed Jan 25, 2017 7:21 pm
rossjm11 View the latest post
There are no new unread posts for this topic. Dura Ace 9100/9150 noisier than 9000!
James0133
11
3069
Sun Aug 20, 2017 5:44 am
James0133 View the latest post
There are no new unread posts for this topic. 28C tyres on Dura Ace 9000 Brake Calipers
chutneyyy
Thu Jun 29, 2017 7:58 am
Delorre View the latest post
There are no new unread posts for this topic. Dura Ace 9000 chainset on a track bike
jay cee
Fri Nov 25, 2016 5:12 pm
11.4 View the latest post
Users browsing this forum: Baidu [Spider], Bing [Bot], jever98, jonouk2 and 34 guests
