It is currently Tue Jan 23, 2018 5:20 pm
Post new topic  Reply to topic  [ 30 posts ]  Go to page 1 2 Next
PostPosted: Wed Jan 11, 2012 10:51 pm
Trying to build up my new bike, I am decided for definite on the frame and i also want deep section wheels (preferably zipp). Below is my list of components with weights. Can anyone think of any cost effective swaps they would make to make it lighter without removing parts?!! The one weight in my list i am unsure of is the handlebar
Before anyone mentions it, i am aware of how long this took.....
Frame
Frame giant tcr advanced sl isp medium (uncut) 820
Headset
Headset cane creek 68
Top Cap specialized 12
Bolt silver 8
Spacers carbon 12
Fork
Fork giant tcr advanced sl isp fork(uncut) 330
Cranks
Arms ultegra driveside 502 crank 200 preload 4 706
BB shimano bb6700
Derailleurs
Front Sram red 58
Rear Dram red 153
Chain
Chain ultegra 256
Cassette
Cassette ultegra 234
Lockring ultegra 6
Wheels
Frt wheel Zip 404 772
Rear wheel Zipp 404 886
Pedals
Pedals look keo 2 max 260
Brakes
Front ultegra no pads 124
Pad holders ultegra no pads 26
Front pads 2 pads 12
Rear ultegra no pads 118
Rear pads 2 pads 12
Levers
shft lever pair Sram red 280
Handlebars
Bars FSA Plasma Integrated Compact White 370
Bar tape/Grips specialized white black 40
Bar end plugs 2 x specialized expandable 18
Stem
Stem Included in bars
Seating
Saddle secialized toupe 143 white 215
Seatpost Included in frame
Seat collar Included in frame
cab/hous
Brake cables Standard 24
Brake housing Jagwire 70
Shift cables Standard 32
Shift housing Jagwire 52
Tires
Frt tire specialized sworks tyre 700 x 23 182
Rear tire specialized sworks tyre 700 x 23 182
Tube front specialized turbo 80mm 68
Tube rear specialized turbo 80mm 68
Misc
Bottle cage 1 specialized ribcage white 38
Bottle cage 2 specialized ribcage black 38
Cage bolts 1 specialized black 1
Cage bolts 2 specialized black 1
Misc extra
grease and such averaged 22
Total in grams 6600
Total in pounds 14.5505212
PostPosted: Wed Jan 11, 2012 11:23 pm
If it were mine, I'd ditch the FSA Plasma in favour of separate bars & stem. In the first place it's better to be able to adjust the angle of the bar relative to the stem, secondly FSA are notorious in their inability to read a set of scales or tell the truth.
Bottom bracket on the Advanced SL is pressfit so I think you're limited to Dura Ace.
With the money saved on the bars, upgrade top Sram Red callipers and perhaps a better crankset.
PostPosted: Wed Jan 11, 2012 11:43 pm
I had gone with the bars for stifness but what your saying does make sense, any suggestions on bars/stem?
Also any good cranksets in mind?
PostPosted: Wed Jan 11, 2012 11:47 pm
Bars are personal. Suss out what you like the shape of and go from there.
I use Deda Zero 100 for both.
WRT cranks, Dura Ace perhaps or Red?
PostPosted: Thu Jan 12, 2012 12:04 am
With the bars I'm thinking 420mm width with a shallow drop
Will see if I can get the weights for the red and DA chain set, also the red calipers and see what it does to the weight.... Would love to get it below 14.....
PostPosted: Thu Jan 12, 2012 12:45 am
I'd question frame weight. Is it real? Including seat clamp, RD hanger, cable guide, etc?
KMC XL chain.
Lighter saddle 125-150g max.
Aim for bar/stem 300-325g.
I'm trying conti 50g tubes right now.
With the wheels I guess you're going for aero over weight.
There's sometimes a buggy.
One.
PostPosted: Thu Jan 12, 2012 12:51 am
Frame weight is correct although it's an a medium an I need a medium large.
Wheels are for aero rather than weight
Will look into saddles as well, this was just the one I had already, seems to be large jumps in prices to get any lighter
PostPosted: Thu Jan 12, 2012 2:21 am
Planet X CNC Brakes
$175
200g
PostPosted: Thu Jan 12, 2012 10:17 am
good suggestion wolfesquire, hadnt seen those... have you tried them?
PostPosted: Thu Jan 12, 2012 10:58 am
I'm guessing in the coming months you'll be able to pick up red cranks and brakes off ebay and craigslist at increasingly good prices....
But you will need a new pressfit BB as well.
What are you using for QRs?
Are the specilized tires actually any good?
PostPosted: Thu Jan 12, 2012 12:17 pm
the tryes are really good, i would only use specialized tyres, been using them for years now and there top quality. The winter armadillo tyres are brilliant.
Was just running with the standard zipp QRs... any suggestions there?
PostPosted: Thu Jan 12, 2012 1:27 pm
Online
Is that frame weight verified on the scales? I'd be amazed if it is. I'd expect a M TCF to be much nearer 1KG, and I predict your build will be more like 6.9KG when built up.
Avoid the SRAM Red/Ultegra mish-mash is my main piece of advice. Will look like 5hit frankly.
PostPosted: Thu Jan 12, 2012 1:39 pm
yeah, its the brakes I have and love them. The KCNC C7s are lighter, but a lot more expensive.
PostPosted: Thu Jan 12, 2012 1:54 pm
mikem86 wrote:
Frame giant tcr advanced sl isp medium (uncut) 820gr
820gr? Are you sure?
My 6532gr TIME Skylon
My 9733gr COLNAGO Master X-light
PostPosted: Thu Jan 12, 2012 2:03 pm
mish mash is just because i already have an ultegra groupset which i can use some of.
I have a large frame here, i will weigh it later on and see how it comes up. The medium weight came from someone else weighing it for me
There are no new unread posts for this topic. Birthday build.... looking for suggestions
jever98
7
848
Mon Mar 06, 2017 10:35 am
jlok View the latest post
There are no new unread posts for this topic. Looking for a new road bike? Build from beginning? Suggestions are welcomed!
edgeman
Thu Feb 02, 2017 4:12 pm
edgeman View the latest post
There are no new unread posts for this topic. New Fork for the Look 585. Suggestions?
Catagory6
Thu Dec 07, 2017 3:41 pm
Svetty View the latest post
There are no new unread posts for this topic. Suggestions for finishing bar tape ?
wobbly
22
2012
Sat Jul 15, 2017 6:11 am
Nefarious86 View the latest post
There are no new unread posts for this topic. First Power meter suggestions
[ Go to page: 13 4 5 6 7 ]
merser
91
8331
Wed Aug 02, 2017 5:38 pm
evan326 View the latest post
Users browsing this forum: 5DII, amey, AZR3, caad4rep, dcorn, MayhemSWE, Monkeyfudger, nmx, stubob and 46 guests
