Lightest cassette
Luca79
by Luca79
What are the lightest cassettes on the market?
Something that would still be reliable and with nice functionality.
11-27 or 11-26 , compatible with Sram Red 10V.
I was thinking about the KCNC full titanium, but have read not much feedback on that one.
Thanks!
konky
by konky
The Kcnc Ti cassette is the one to get but ratios are limited and it's expensive. They only do a 11-23 for compact but on initial trial it runs even smoother and quieter than a 7900. That is saying something as the 7900 is a great cassette. Only Shimano so Red compatible.
bura
by bura
12-25 . 84 gram.369US Dollar.
Reliability? Functionality?
http://www.ceradure.nl/cycling/products.php?sub=59
Kuota Kom Evo
viewtopic.php?f=10&t=111825&p=955235#p955235" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
SOLD
jmartpr
by jmartpr
We have sold 2 of the new KCNC full Ti.....as mentioned they shift very good and look awesome.
They are a bit expensive at close to $400 but compared to a Campy Super Record that only offers 6 sprockets in Ti it doesn't look that bad :wink:
Both owners use these cassettes daily for the past 6-7 months and so far they have hold very well.
Mattias Hellöre
by Mattias Hellöre
You can use a aluminum cassette, but be careful when you shift, never under full power, ease off when shifting.
Ceradure/TiN coating whatever does no measurable difference besides the looks and corrosion stability.
The aluminium core is much softer than the coating so the coating will crack and then fall off.
Experimental Prototype
voodoojar
by voodoojar
If you go with a 12-25 or 12-27 you can get with all alloy gears rather than the 11t steel gear, that saves weight. or you can get the 11t from nino that is titanium.
I don't have a photo of a 10 speed one on the scale but here is a 9 speed 12-27 . the ten speed one weighs almost exactly the same. Which is really good for a 12-27. Image
TimmS
by TimmS
There is a review from Bikeradar on the ceradure cassette...
http://www.bikeradar.com/gear/category/ ... e-11-45379
jmartpr
by jmartpr
Another thing about Alloy cassettes is that teeth are thicker/beefier so they last longer and don't break under power/shifting.
This creates the shifting smoothness problem that most Alloy cassette have and the long break-in period when they are new.
This is one of the reasons KCNC is moving all cassettes to full Ti.
Luca79
by Luca79
konky wrote:The Kcnc Ti cassette is the one to get but ratios are limited and it's expensive. They only do a 11-23 for compact but on initial trial it runs even smoother and quieter than a 7900. That is saying something as the 7900 is a great cassette. Only Shimano so Red compatible.
Don't they do a 11-27 for a 50-34 compact?
mnmasotto
by mnmasotto
I had the KCNC Sc/Al/Ti 10-speed Campy compatible road cassette but could never get it to shift correctly. My LBS gave it a go without any success either. I would love to find a light cassette which could be used on a daily basis with my Di2.
CBRE
by CBRE
The new Red is right around the corner with a nice weight savings without the worry of reliability.
Curt Brown
2016 Cannondale EVO Etap 13.8#'s
2012 Cannondale Supersix EVO etap 13.7#'s
2017 Cannondale SUPER X Force 16.0#'s
2016 Cannondale FatCad2 28.1#'s
2011 Cannondale Carbon Flash 1 17.9#'s
mypz4
by mypz4
1000 + miles on kcnc ti, sc ,al campagnolo and perfect shifting from day one
konky
by konky
mnmasotto wrote:I had the KCNC Sc/Al/Ti 10-speed Campy compatible road cassette but could never get it to shift correctly. My LBS gave it a go without any success either. I would love to find a light cassette which could be used on a daily basis with my Di2.
The Kcnc Ti cassette works really well with my Di2. It is also a really beautiful looking bit of kit. I first tried an Omni Racer one which didn't work. I've been told by a very reliable source that the Kcnc Ti is the only aftermarket cassette that does work well with Di2. I haven't tried all of them so I am only going on what I have been told in respect of non Kcnc aftermarket cassettes.
But as I already said at present there isn't a Campy version and you can only get a 23 with an 11T.
PS The Omni Racer does work with a machanical drivetrain and is a lot cheaper.
prendrefeu
by prendrefeu
1415chris
by 1415chris
11-23 recon
1/3 price of ceradure. Not much mileage on it so far, but can't see what wrong can go with this cassette.
There is slightly small delay in shifting compared to red one, but not something that can spoil your riding experience, imo.
