A closer look at "by and" manufacturing from DeRos
http://www.cyclingtime.com/modules/movi ... 00506.html
(Requires Quicktime. If you don't have it yet: www.quicktime.com)
divve, are you starting your own one man crusade against Italian branded bicycles!
LJ wrote:divve, are you starting your own one man crusade against Italian branded bicycles!
I actually thought it was interesting. The part that wasn't shown, aside from the design and mold stage, is the prep necessary to make the frame ready for gluing. Although not very high-tech the gluing stage isn't as simple as it appears to be.
VVV wrote:To their credit, he never mentioned anything about doing everything by yand.
Near the end he said it once and it sounded the same as the other guy
divve wrote:I actually thought it was interesting.
Indeed it was.
He basically said they chose this method of production to allow for custom geometry. That it's important to use the right amount of glue and curing technique. Finishing/matching of the joints is by hand, and taped ready for the curing in the oven at 130c I believe.
Correct, the separate carbon components are by Mizuno.
