Post new topic Reply to topic  [ 214 posts ]
Go to page Previous  1, 2, 3, 4, 5, 6 ... 15  Next
 Post subject: Re: Slammed stems...
PostPosted: Mon Jan 02, 2012 10:25 pm
2ndgen wrote:
celeste55 wrote:
A 15-10 mm spacer underneath the stem is not a slammed stem.
So the definition of "slammed" sub-10mm?
I like the 10mm max now.
The definition of slammed stem would be the stem resting directly on top of the headset cap. Slammed stem would not apply to headset caps like those tall conical ones seen in the above Cannondale pictures. The stem would also have to be in the negative position. And as someone mentioned above, you would really have to use a -17 stem instead of those higher -8 -10 stems. Slammed means as low as possible given commonly available bicycle parts. Flat headset caps and -17 stems are commonly available.
PostPosted: Mon Jan 02, 2012 10:29 pm
slammed just means on top of the headset cap, i don't think stem depth has anything to do with it
PostPosted: Mon Jan 02, 2012 10:39 pm
http://slamthatstem.com/page/12
PostPosted: Mon Jan 02, 2012 11:17 pm
I thought slammed meant going down to one spacer between the top of the headtube and bottom of the stem. Well then, I stand corrected.
Not "slammed", but I want it capped flush at the top with a max of 10mm and a minimum 5mm under.
I'm diggin' these...
This, I like...
Of course, I'm LOVIN' this!
(I got the pics from slammedstem. If either of these are you bikes, sorry.)
Project CAAD9 7.2kg
The CAAD Build Thread
PostPosted: Mon Jan 02, 2012 11:51 pm
Ryder Hesjedal has the ultimate slammed stem. He doesn't even use a top cap.
http://www.slipstreamsports.com/2011/05 ... rvelo-r5ca
PostPosted: Tue Jan 03, 2012 12:16 am
The caad9 is this dudes
http://tarckstar.tumblr.com/
PostPosted: Tue Jan 03, 2012 8:14 pm
I'm about to cut my steerer down and get rid of the stack of spacers pictured in the thread above.
Cannondale says to cut the steerer 2mm below the top of the stem, and run with no spacers on top of the stem.
I have heard others say to always run a spacer above the stem- which Cannondale forbids, expressly, here: http://cdn.cannondale.com/Manuals/2006_ ... ent_en.pdf
Do I follow Cannondales instructions, or previous advice?
PostPosted: Tue Jan 03, 2012 10:10 pm
Time frames are the same way. I think it is because the headset and top cap supplied with the frame and fork are made in such a way to support the steerer tube of the fork to a certain depth which is the stack height of the stem that clamps to the steerer tube. If you use spacers on top of the stem, that part of the steerer tube will not be supported by the top cap.
Hope that makes sense.
TIME RXR
PostPosted: Tue Jan 03, 2012 11:54 pm
I use a custom top cap
PostPosted: Wed Jan 04, 2012 12:28 am
A totally slammed stem suggests a badly fitting frame to me. The other alternative is that the frame is 100% perfectly fitting, but then who is so sure about their ideal stem height that they are certain that they will never want to adjust it by as much as 5mm either way? A perfectly fitting frame to me would be one with a little room for tweaking.
Of course quite a few pros ride less than ideally fitting frames because the high-end ones are often designed for the middle aged people who can afford to buy them.
PostPosted: Wed Jan 04, 2012 12:47 am
You guys need to get with the program.
PostPosted: Wed Jan 04, 2012 12:49 am
Incredible!
10 SuperSix Hi-Mod
07 System 6.
06 Caad 8
90s Merlin Extralight.
PostPosted: Wed Jan 04, 2012 1:37 am
Niiiiice, but for the love of the family jewels I would not ride that thing with the saddle's nose pointing up like that :shock: .
It's not how much you spend on a bike it's how hard you can ride it.
PostPosted: Wed Jan 04, 2012 2:13 am
Online
Sometimes you have no choice but to try to stuff yourself onto whatever geometry the manufacturer has made its moulds for. As neeb notes, the problem is the headtube lengths on the monocoque frames are too tall for a perfect fit for lots of people, so you end-up with a saddle slammed back on the rails of a setback post and a 140mm stem slammed down onto the topcap to get a bike that fits.
PostPosted: Wed Jan 04, 2012 2:43 am
Stem heights are relative. Higher for more comfort. Lower for a more aggressive position.
A rider can have a generally perfect frame size, but alternate stem positions to accommodate riding style.
How can a manufacturer design a frame that is perfect for more than one human being ever?
No two human bodies are identical in dimension. A frame is just the reference point to start from.
After that, stem height/length/angle, saddle height/shape, crank arm length, handlebar width/drop/shape
all have to be taken into account to design a custom fit. Slamming a stem might be a solution to someone
and their style of riding that an OEM position didn't offer. How can that ever be wrong?
:thumbup:
Project CAAD9 7.2kg
Post new topic Reply to topic  [ 214 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 15  Next
Users browsing this forum: Exabot [Bot], Google Adsense [Bot], Wookieopolis and 57 guests
There are no new unread posts for this topic. 3T stems - which one is the stiffest?
Permon
Tue Apr 30, 2013 4:15 pm
carlislegeorge View the latest post
There are no new unread posts for this topic. -8 degree stems
gg333
7
675
Mon Dec 03, 2012 9:42 am
Spindoctor View the latest post
There are no new unread posts for this topic. Deda 35 bars and stems
seve88
Thu Jan 10, 2013 11:45 pm
cwdzoot View the latest post
There are no new unread posts for this topic. -17 degree stems for 1.25" steerers
CarpetFibre
14
688
Fri May 17, 2013 2:58 pm
hubert222 View the latest post
There are no new unread posts for this topic. Small bikes, long stems?
phourgenres
29
2155
Thu Jun 13, 2013 6:43 pm
eric View the latest post
It is currently Tue Jun 18, 2013 5:48 am
