Post new topic Reply to topic  [ 214 posts ]
Go to page Previous  1 ... 7, 8, 9, 10, 11, 12, 13 ... 15  Next
 Post subject: Re: Slammed stems...
PostPosted: Sat Apr 21, 2012 2:48 am
Took care of the requoting of the quote. C'mon guys...
Now... :back2topic:
Cervelo R3, Campagnolo Chorus/Record mix... pastatrails.blogspot.com
PostPosted: Sat Apr 21, 2012 12:41 pm
Campagnolo Hiddenset 5.9mm height
Winter & commuter bike
It's online again:The Machinist
PostPosted: Sat Apr 21, 2012 1:23 pm
Now... :back2topic:
Sorry for the heinous offence.
PostPosted: Sun Apr 22, 2012 6:32 pm
Regardless of how high my bars need to be, I don't run headset spacers on any of my bikes. I like to eliminate spacers because I've found that it stiffens up the front end significantly. Saving a few grams is another bonus.
You can take your current stem length and the height of your spacer stack and do a little trigonometry to calculate what length/rise stem you need to eliminate your spacers and keep the same bar height.
That's right: trigonometry. Shit just got real. 8)
PostPosted: Mon Apr 23, 2012 3:49 am
http://alex.phred.org/stemchart/Default.aspx
α
PostPosted: Tue Apr 24, 2012 1:17 am
You are forgiven. :wink:
Jokes aside, wading through three or four posts that requote the same pictures one after another is annoying. Thanks.
PostPosted: Tue Apr 24, 2012 2:11 am
The most slammed... without putting it on the bearing
The silver one is a prototype of a product i developed to slam stems. http://slamthatstem.com/headset-bearing-cover
slam on.
PostPosted: Tue Apr 24, 2012 7:40 pm
*yes the saddle angle has been fixed
PostPosted: Tue Apr 24, 2012 7:42 pm
youve got the bars and hoods correct at least! foolishly rotating them up is far too common.
α
PostPosted: Tue Apr 24, 2012 8:44 pm
Does anyone know if the slam the stem top caps will fit on cane creek 40 headsets?
they have these two seals that sit on top that make it so the cannondale top cap wont sit properly .... thoughts?
Just ride ..
PostPosted: Tue Apr 24, 2012 9:11 pm
should* , the only difference between is40 and is42 (which caad10 is) is the diameter. it'll work, it'll just be wider than than the is40
PostPosted: Tue Apr 24, 2012 9:14 pm
The cap sits on the headset and drops down about a couple mm to touch the front tube. The hole fits a 1-1/4 steerer. Hopefully that's enough info for you.
PostPosted: Tue Apr 24, 2012 9:17 pm
The slam that stem top dust cap was designed with cannondale headsets in mind, so i'd imagine that it won't work with yours
PostPosted: Tue Apr 24, 2012 9:19 pm
Understood and no problem. :thumbup:
PostPosted: Fri Apr 27, 2012 10:17 pm
your bike is on bike rumor, your welcome ;)
http://www.bikerumor.com/2012/04/27/sla ... that-stem/
Post new topic Reply to topic  [ 214 posts ]  Go to page Previous  1 ... 7, 8, 9, 10, 11, 12, 13 ... 15  Next
Users browsing this forum: ave, Bing [Bot], jeffbong, koebes, Leviathan, Rappid, wassertreter and 42 guests
There are no new unread posts for this topic. -8 degree stems
gg333
7
647
Mon Dec 03, 2012 9:42 am
Spindoctor View the latest post
There are no new unread posts for this topic. 3T stems - which one is the stiffest?
Permon
Tue Apr 30, 2013 4:15 pm
carlislegeorge View the latest post
There are no new unread posts for this topic. 2 Cracked stems? Deda and ITM
xcnick
Mon May 28, 2012 9:44 pm
xcnick View the latest post
There are no new unread posts for this topic. Deda 35 bars and stems
seve88
Thu Jan 10, 2013 11:45 pm
cwdzoot View the latest post
There are no new unread posts for this topic. -17 degree stems for 1.25" steerers
CarpetFibre
14
643
Fri May 17, 2013 2:58 pm
hubert222 View the latest post
It is currently Thu May 23, 2013 10:32 am
