Post new topic Reply to topic  [ 45 posts ]
Go to page Previous  1, 2, 3  Next
 Post subject: Re: Ultegra Di2 hacking
PostPosted: Tue Jan 03, 2012 4:59 am
http://fairwheelbikes.com/forum/viewtop ... 73#p100573
I just posted some pictures here.
PostPosted: Tue Jan 03, 2012 5:01 am
chipg wrote:
I ran into the same issue trying to use some very small batteries that will slip inside the frame near the bottom bracket of my Tarmac SL4. I connected my batteries through the battery mount (with alligator clips) and this does work, verifying that the ID chip is in the battery mount.
The mount itself is 24.5 grams without the easily removed hardware. It is much too big to go inside my frame and is glued together - I don't think it can be taken apart without cutting it up. It may be possible to remove the circuit board by destroying the plastic housing.
Besides the cludgy stock mount and saving battery weight (mine are 21 grams for the two) I would like to be able to play around with additional shifter switches. I connected an oscilloscope and the signals are evident on top of the battery voltage. I can't tell if it is actually a CAN signal - it says so in various places on the internet but it is difficult to tell if one person made this up and got copied. If so it would not be very difficult to hack.
Chiva, please keep us posted on dismantling the battery mount!
I don't know if this image will work.
Was the negative clip on the terminal the one closest to the frame? I just want to double check before I fry something:)
PostPosted: Tue Jan 03, 2012 7:35 am
File comment: look at this
 Post subject: Ultegra Di2 hacking
PostPosted: Tue Jan 03, 2012 7:42 am
chipg wrote:
I believe the cpu is in the front derailleur but have not verified this.
I took off the front derailleur wire and it still worked.
Could the CPU be in adjusting block?
-- Bianchi Oltre Ultegra Di2 -- Cube Elite 29 Super HPC XTR -- Cannondale SuperX Ultegra Di2 -- Cannondale Jekyll XT -- Cannondale Capo --
PostPosted: Tue Jan 03, 2012 9:53 am
In di2 there is no single 'cpu' or 'brain'. It's a distributed networked system with some processing capability at each point. Just like a bunch of computers on a LAN. They each tell the others what they are doing and broadcast commands and status. I suspect ui2 is the same.
PostPosted: Tue Jan 03, 2012 4:59 pm
Negative is closest to the frame/flat end. See di2diy's photo.
PostPosted: Tue Jan 03, 2012 5:09 pm
Thanks for your help in easing my paranoia di2diy and chipg. Much appreciated:) I have confidence now that when I solder those wires to the battery mount I'll be in business.
PostPosted: Tue Jan 03, 2012 9:11 pm
I would guess that you might just be seeing spikes in current on the battery line from turning on the motor as you activate the shifter. I really doubt that they'd put the communication superimposed upon battery lines. If shimano used an off-the-shelf battery authentication chip, then one could just make their own circuit after buying the same chip and use it with an aftermarket battery. Unfortunately, I would bet on shimano using either an unmarked, or proprietary authentication chip to prevent exactly what we're discussing. Until someone cuts apart the battery mount and verifies what's inside, we won't really know.
PostPosted: Tue Jan 03, 2012 10:01 pm
Since there are only two wires in the entire system they have clearly superimposed the signals on the power. This is not an unusual thing to do.
PostPosted: Tue Jan 03, 2012 11:35 pm
As suggested by did2iy, I just tried splicing into the circuit and powering up the battery holder (and everything else) from the round Shimano connector side. This doesn't work. Power needs to go through the battery holder from the battery side.
PostPosted: Wed Jan 04, 2012 2:25 am
After I posted that and thought about it I wanted to retract it, of course there must be some sort of diode in the circuit. Sorry about that.
PostPosted: Wed Jan 04, 2012 2:57 am
How about something like this
File comment: battery on this end, any 7.4v 20c battery should work
File comment: cut this from the mount, if it has the chip it should work
PostPosted: Wed Jan 04, 2012 5:46 pm
Yes but worth the try if it had worked. It looks like I will have to cut up the mount. I plan to wait a bit hoping that someone produces a board.
PostPosted: Thu Jan 05, 2012 12:39 am
Exactly, in every part in the Ultegra DI2 group is a micro-controller so it can communicate with the other parts. The current Dura Ace shifters have no electronics in them, but the Ultegra shifter do have a small board with a micro-controller.
I posted on Fairwheelbikes some results of my measurements.
PostPosted: Mon Apr 15, 2013 7:28 am
Hi there,
I just wonder if there are any news?
Are there any little helpers out there for connecting individual 7.4 batteries?
Post new topic Reply to topic  [ 45 posts ]  Go to page Previous  1, 2, 3  Next
Users browsing this forum: anderz, Google Adsense [Bot], gospastic, Kermithimself, Majestic-12 [Bot], maverick_1, Nismo4x4 and 47 guests
There are no new unread posts for this topic. Hacking Di2 firmware to do single-lever shifting
freeloader
7
1228
Fri Jan 04, 2013 6:20 pm
Squint View the latest post
There are no new unread posts for this topic. Shimano Ultegra 12-30 Cassette With Ultegra Di2?
SpeshK
Tue Feb 05, 2013 5:13 pm
SpeshK View the latest post
This topic is locked, you cannot edit posts or make further replies. Dura Ace Di2 from Ultegra Di2
DamoRider
Sun Jan 27, 2013 8:36 pm
DamoRider View the latest post
There are no new unread posts for this topic. Ultegra Di2 New Firmware
goodboyr
16
3089
Fri Sep 14, 2012 7:27 pm
Toby View the latest post
There are no new unread posts for this topic. Is Ultegra Di2 compatible with the new DA Di2?
limba
Tue Mar 19, 2013 6:15 pm
ms6073 View the latest post
It is currently Sun May 19, 2013 5:46 pm
Shimano Ultegra Di2 components at cheap prices - starbike.com
