Post new topic Reply to topic  [ 111 posts ]
Go to page Previous  1, 2, 3, 4, 5 ... 8  Next
PostPosted: Sat Dec 10, 2011 12:34 am
Thomson X2 ftw
Plain graphics too so you can use it with any bar.
 Post subject: About me...
PostPosted: Sat Dec 10, 2011 1:00 am
I am a bigger guy at 185lbs, can reliably put down 1000w in a sprint but at my best was about 1200W. I want a stem which is good for my favorite kind of riding such as crits but also don't want to get beat to hell on longer rides. That it sort of why I chose the Hi-mod over a CAAD10, it just felt a bit smoother and at 36 my body doesn't enjoy the beatings it took when it was 18 and riding a Cannondale 2.8 =P
So I am looking for a good blend of something not too noodley but also comfortable. Weight isn't really an imperative (I've been fading from weeniedom after realizing however lightweight my KCNC CB1s were, they just plain sucked). I like the 3t ARX but will look up a few of the other suggestions as well. Thanks!
Rob
PostPosted: Sat Dec 10, 2011 1:11 am
I have 3T Arx LTD on my 595 and love it, never knew I'd be able to tell the difference (previous was Deda Zero100 and Rotor Sx) or give a sh*t about a stem but it is WAY more stable and solid feeling, love it...
PostPosted: Sat Dec 10, 2011 9:17 am
theremery wrote:
Ritchey WCS 4AXXIS are cheap, lightish (about 100-120g depending on length and if you use Ti bolts) and rigid enough for most people. You CAN flex these stems but more flex comes from the bars than the stem with a normal bar.
I like Ritcheys WCS 4Axis stems.I have used different lengths of the standard,the 44,the 44 for 1 1/4 steerer (Canyon).Be sure to get the "44" version if you want a little extra stiffness.
PostPosted: Sat Dec 10, 2011 10:26 am
I peak a 1500w sprint and have a 5sec avg output of 1350, the Ritchey stem is OK, but I like it a little bit stiffer.
I used Ritchey WCS alu bar/stem earlier, but I'm now on 3T Arx pro/Ergonova pro and like the added stiffness a lot. I'm guessing the bars have more to say on this than the stem itself.
WTB: MTB hubs, 29'er carbon rims
My 7.3kg/6.4 kg 29'er project buildthread!
My Bianchi Oltre XR
PostPosted: Sat Dec 10, 2011 11:57 am
MaLóL wrote:
syntace f99 26.0
best stem produced so far imho.
Wrong! The extralite stems are THE best stems you can get and they just look so good!
http://fairwheelbikes.com/cycling-blog/ ... ee-z5.html
PostPosted: Sat Dec 10, 2011 1:50 pm
They do look the part 8)
RUEGAMER 5.21kg, 11.48lbs
CRUMPTON 4.40kg, 9.70lbs
PostPosted: Sun Dec 11, 2011 10:29 am
Nobody mentioned this beauty
Cervelo R5 VWD 5637g/12.43lb
Cannyon Ultimate slx 5592g/12.33lb
Pronghorn XC SW Race 8284g/18.26lb
PostPosted: Sun Dec 11, 2011 11:54 am
yea na...
PostPosted: Sun Dec 11, 2011 4:54 pm
I did! Still have Rotor on the MTB and its great, never thought it would hold up as well as it has, it would be my #2 choice for road.
PostPosted: Sun Dec 11, 2011 5:00 pm
its not like a "soft" stem will get your sprint wattage drop by 50W... And a stiff stem wont beat you on a long ride... There is so much more to it.
As someone previously stated, I dont think stem stiffness is noticeable for general road riding and racing.
2013 rocky mountain vertex 29er
­Twitter
www.cyclingtrainingnuts.blogspot.ca
PostPosted: Sun Dec 11, 2011 5:28 pm
I think because of the unusual way to install your bar.
the screws of the front plate have on both sides thread and that is unusual .
PostPosted: Sun Dec 11, 2011 5:43 pm
sugarkane wrote:
MaLóL wrote:
syntace f99 26.0
Wrong!! extralite stem corners and edges look so weird. syntace f99 looks much better and the rubber inserts on the clamp is a very smart system. also its construction is much better/stronger, it has bigger bolts with normal allen hey. not so delicate as the extralite and well proven on test banks. also f99 comes with a great headset cap...
Happy trails !!!!!
PostPosted: Sun Dec 11, 2011 5:58 pm
MaLóL wrote:
sugarkane wrote:
MaLóL wrote:
syntace f99 26.0
The look is subjective. I love the design of the extralite, the clean bolt-less rear end looks great on any bike and most importantly it's 20g lighter than the f99.. The small bolts arn't that fragle any more with the new torx head..
PostPosted: Sun Dec 11, 2011 7:49 pm
Not the craziest, lightest, flashiest or probably stiffest stem out there, but I've been riding a FSA OS-99 Aluminum stem for a few years now, and its never let me down. Not to mention, at only 113 grams for the 100mm version, its not heavy either. Yes, there is lighter, but I would be willing to bet, that for the money, you can't do much better...
Post new topic Reply to topic  [ 111 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 8  Next
Users browsing this forum: Bing [Bot], Exabot [Bot], hansonator69, headwind816, mattjevans, Miller, mpower, PSJoyce, Shinobi, TiG, tommasini and 50 guests
There are no new unread posts for this topic. Do latest wide profile wheels increase rolling resistance?
dynaserve
44
2692
Thu Jan 24, 2013 12:02 am
fdegrove View the latest post
There are no new unread posts for this topic. -8 degree stems
gg333
7
651
Mon Dec 03, 2012 9:42 am
Spindoctor View the latest post
There are no new unread posts for this topic. 3T stems - which one is the stiffest?
Permon
Tue Apr 30, 2013 4:15 pm
carlislegeorge View the latest post
There are no new unread posts for this topic. 2 Cracked stems? Deda and ITM
xcnick
Mon May 28, 2012 9:44 pm
xcnick View the latest post
There are no new unread posts for this topic. Deda 35 bars and stems
seve88
Thu Jan 10, 2013 11:45 pm
cwdzoot View the latest post
It is currently Sat May 25, 2013 1:43 pm
